Warning message
Whisper and Agent Greeting
Answered Question
Jun 20th, 2012
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi ,
I had a query  on whisper and Personalised Agent Greeting supported in UCCE 8.5.
Can't we configure both the above features and make them work simultaneously for call which is landing to agent?
regds,
aman
Correct Answer by brian1mcc about 5 years 1 month ago
Yes you can ...
You can use Agent Greeting along with the Whisper Announcement feature. Here are some things to consider when using them together:
- On the call, the Whisper Announcement always plays first, before the Agent Greeting.
- To shorten your call-handling time, you may want to use shorter Whisper Announcements and Agent Greetings than you might if you were using either feature by itself. A long Whisper Announcement followed by a long Agent Greeting equals a long wait before an agent is actively handling a call.
- If you use a Whisper Announcement, your agents probably handle different types of calls: for example, “English-Gold Member-Activate Card,” “English-Gold Member-Report Lost Card,” “English-Platinum Member-Account Inquiry.” Therefore, you may want to ensure the greetings your agents record are generic enough to cover the range of call types.
source: http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/ipcc_enterprise/ipccenterprise8_5_1/configuration/guide/agwa85fg.pdf
(page 18)
Brian
Please rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
brian1mcc Thu, 06/21/2012 - 03:43
  • Silver, 250 points or more
Yes you can ...
(page 18)
Brian
Aman Soi Thu, 06/21/2012 - 07:36
    2017 IP Telephony
Hi Brain,
Thanks a lot.
regds,
aman
Related Content
