3750x Management Port - No Connection in SWITCH: mode
Jun 20th, 2012
Hi Guys,
I'm trying to get an IP_ADDR set on the management port in SWITCH: mode but for some reason the port seems disabled. PC shows connection unplugged. MGMT_INIT is not a valid command (not listed under '?' ). Bootloader version is 12.2(53R)SE2 FC1. Any ideas?
Mike
Reza Sharifi Wed, 06/20/2012 - 16:58
The port is fastethernet interface.
make shire your PC or laptop in connected to this port than
Try this
config t
interface FastEthernet0
ip address 172.16.1.1 255.255.255.0
no sh
than
sh ip int bri fas0
michael.lorincz Thu, 06/21/2012 - 07:53
Thanks for the reply Reza. I should have clarified I'm in recovery mode (assume no IOS). The port works in the CLI but not in rommon/switch: mode.
- Mike
Reza Sharifi Thu, 06/21/2012 - 08:20
Mike,
If you are in recovery mode, than this is not going to work.  You would need to use Xmodem to load a new version of IOS.
once the IOS is completely loaded than you can use the Ethernet port.
Related Content
