iphone does not automatically associate with 1142N AP
Answered Question
Hello!
I am testing our new wireless network using
1 Cisco 2504 wireless controller with 5 licenses
4 Cisco Air LAP 1142N Access Point
I configured it very simple for testing
There is only one interface and vlan is untaggetd
There is also only one WLAN with one SSID
Currently security setting is WPA + WPA2 + PSK (I also tested with no security setup)
Wlan session time is diabled and controller user idle timeout is set to 1000000 (Max)
AP boot version is 12.4.23.3 and ISO version is 12.4(23c)JA3
Problem is clinet(iphone) does not automatically associate with 1142N Access Point
even after it learned network. Phone has to be authenticated again to connect to network
same iphone can automatically associate with old 1220 Access point but not with New AP
if I urn off and turn back on wifi from iphone, it does see the network but does not connect
but I have to manually reconnect to it with password
I want iphone to connect known network without reauthentication process after iphone's wifi function is turn on
Did I miss any setting for this or am I dreaming?
Thank you
Correct Answer by daviwatk about 4 years 10 months ago
So what's the problem?  You associated, make proper key exchange, perform DHCP, and enter the RUN state.  Looks like everything is going good until 12:39 when the M5 group broadcast key is updated and the client doesn't respond.  My guess is that it is "sleeping".  We end up deauthenticating the client from the AP.  Other than that, it appears the client connected just fine and received an address.
It sounds like you're asking why you have to keep re-typing your PSK everytime you attempt to "initially" connect to the WLAN.  Sounds like a client issue.  Have you tried to perform a "Reset Network Connections"? https://discussions.apple.com/thread/2299836?start=0&tstart=0
Settings > General > Reset > Reset Network Settings
Looks like several other iDevice users have hit this.  When they "reboot" they phone it will join automatically, however if they are "waking" the phone after having been connected, they're beeing prompted for PSK every time.
Irrelevant of the key caching discussed previously, the phone shouldn't forget it's "configured" PSK used to derive it's keys, whether it had appropriate PMKID or not for the BSSID.
Overall Rating: 5 (2 ratings)
Scott Fella Wed, 06/20/2012 - 12:57
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Make sure you only use either wpa/tkip or wpa2/aes and not both or a mix of two. iDevices don't like a mix.
Scott Fella Wed, 06/20/2012 - 18:07
  • Hall of Fame,
    2017 Wireless
So any other clients connect fine? Is it multiple iDevices or just one? Can you post your show run-config and a debug client
Scott Fella Wed, 06/20/2012 - 18:16
  • Hall of Fame,
    2017 Wireless
Have you tried rebooting the iPhone. I run into that issue once in a while and that fixes my issue with my iPhone or iPad.
Scott Fella Wed, 06/20/2012 - 18:30
  • Hall of Fame,
    2017 Wireless
Let me know... It happens to me once in a while and a reboot fixes it for me.
Scott Fella Wed, 06/20/2012 - 18:41
  • Hall of Fame,
    2017 Wireless
I run a 2504 at home with multiplied SSIDs but run into the same issue with my PSK SSID. I might be able to connect to my other SSID, but not my main SSID my iPhone connects to. Just try again tomorrow and see. Did you manually add the wireless profile to your iPhone or did you broadcast the SSID and then clicked on the SSID and have the iPhone prompt you for the PSK?
Leo Laohoo Wed, 06/20/2012 - 20:45
  • Hall of Fame,
    2017 LAN, Wireless
Run the newer code 7.2.X if you have iDevices in your network.  There are improvements particularly iPhone's "flavour" of sticky MAC authentication which can cause issues with lower codes.
Scott Fella Wed, 06/20/2012 - 20:54
  • Hall of Fame,
    2017 Wireless
Leo,
The "sticky" has a limit of 8 access points, so in larger environments, the cache of the keys for the iDevices is limit to 8 access points.
Leo Laohoo Wed, 06/20/2012 - 22:17
  • Hall of Fame,
    2017 LAN, Wireless
Thanks Scott.
  • Hall of Fame,
    2017 LAN, Wireless
7.2.110.0
Scott Fella Thu, 06/21/2012 - 05:34
  • Hall of Fame,
    2017 Wireless
Well I run various code, since I do some beta testing.  I have ran all the 6.x, 7.x code on the 2504 I have.
I tried different brand of laptop, different version of driods, iphones, ipads, blackberry. so far  ipad and iphone are only client which has this problem. Thank you
Correct Answer
daviwatk Thu, 06/21/2012 - 09:55
  • Bronze, 100 points or more
I tried rebooting those iphones but this steps
Yes it solved the both iphones and ipads problem.
Setting > General > Reset > Reset Network Setting
Can you guess how many iphone and ipad I tested had same problem?
I guess now I have to set all previously known networks up again since I just removed the network configuration profile
Thank you
Scott Fella Thu, 06/21/2012 - 12:24
  • Hall of Fame,
    2017 Wireless
Chris,
If you have an issue with every iPad or iPhone after the device goes to sleep, then I would either remove the WLAN and recreate it (no symbols in the PSK) or erase the wlc config and start from scratch.
When I run into issues, it's not every time my device goes to sleep. It might be once or twice a month.
Related Content
