2504 wireless controller - turn off / disable options during off peak hours
Answered Question
Jun 20th, 2012
       I'm configuring a 2504 wireless controller with # of 1142 APs, wondering is there an option to turn off the WLC/ APs during after ofice hours? such as turn off power/RF options etc
Correct Answer by George Stefanick about 5 years 1 month ago
If you have WCS / NCS, you could push a template to the controllers. Not sure about the HP swicthes, I have limited experience with those. On Cisco you can you do a time ACL.
Correct Answer by Amjad Abdullah about 5 years 1 month ago
no option on wlc. you can achieve this however if you have WCS or NCS.
Correct Answer by Scott Fella about 5 years 1 month ago
There is not an option from the wlc. You can maybe use a pdu to power off the wlc on a schedule. I know some switches support shutting PoE ports if you want.
Switches that support Energywise
Overall Rating: 5 (3 ratings)
Correct Answer
Scott Fella Wed, 06/20/2012 - 12:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Correct Answer
Amjad Abdullah Thu, 06/21/2012 - 06:01
  • Red, 2250 points or more
George Stefanick Thu, 06/21/2012 - 07:46
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
What about a "time" ACL on your swicths to do a SHUT to your APs.
prasath_tt Thu, 06/21/2012 - 08:26
I'm not sure about that George.. we have a hp5412zl where the Aps are connected..
is it possible to shut off the ports for a period of time?
Correct Answer
George Stefanick Thu, 06/21/2012 - 11:29
Related Content
