No username in Radius logs if authentication fails
Jun 20th, 2012
I'm running ACS v 5.1 and have noticed that it an autheication fails the log doesn't show the username it there is a failure with the authentication, but if the autheication is successful the username shows up.  Does anyone know how to make it so the failure messages are of value because it shows the username?
Here is an example:
Authentication Summary
Logged At:
June 20,2012 1:01:43.270 PM
RADIUS Status:
EAP session timed out : 24415 User authentication against Active Directory failed since user's account is locked out
NAS Failure:
Username:
MAC/IP Address:
Network Device:
Access Service:
Default Network Access
Identity Store:
AD1
Authorization Profiles:
CTS Security Group:
Authentication Method:
PEAP(EAP-MSCHAPv2)
Tarik Admani Sun, 07/01/2012 - 20:12
  • Green, 3000 points or more
Hi can you post the entire error message, at time the eap session times out before the handshake is complete, once the handshake completes then the users credentials are sent through the tunnel where authentication occurs.
Tarik
Related Content
