Warning message
1262 Indoor and outdoor antennas on the same AP?
Jun 20th, 2012
I have a metal shop that needs wireless indoors and outdoors.
Will it work if I mount the 1262 inside with 4 indoor antennas mounted inside the building and 2 outdoor antennas mounted outside?
Scott Fella Wed, 06/20/2012 - 18:12
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You do not want the antenna configured that way, the multiple antennas is for diversity and beamforming. If you need to cover both then you might need two APs. That is if the ap inside doesn't provide enough coverage outside.
Leo Laohoo Wed, 06/20/2012 - 20:48
  • Hall of Fame,
    2017 LAN, Wireless
Won't work effectively.
Scott Fella Fri, 06/22/2012 - 16:42
  • Hall of Fame,
    2017 Wireless
Just remember its best practice to keep the antennas a multiple of no more than 4 wavelengths if your using external and not the dipoles. A goo measurement is the distance between the RP-TNC connectors on the AP.
Leo Laohoo Fri, 06/22/2012 - 17:51
  • Hall of Fame,
    2017 LAN, Wireless
Thank You. We will get two.
What are you trying to do?
Providing wireless service isn't as simple as "I'll get two of them, thanks".
1.  How big is the area (inside and outside)?
2.  What kind of service?  Voice?  Data?  Video?
3.  What protocol?  802.11 a/b/g/n
4.  What speed are you expecting?
5.  What clients do you have?  Smartphones/Tablets?  Laptops?  Bar-code scanners?
6.  How high from the ground will you be installing the WAPs?
7.  What are the walls made out of?  Wood, concrete, bricks, metal?
8.  What are the shelves made out of?
9.  Wireless site survey?  Have you done one?
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
