cannot create vpc peerlink between 2 NK5-C5548UP-Fa
Answered Question
Jun 21st, 2012
I have very strange problem. I have two NK5-C5548UP-Fa where I need to implement the vpc features. I want my peer link go over an SVI. I have Port-Channel 100 configured as a trunk with 3 vlans in it (my VPC-Peer Vlan included in a seperate VRF, and two data vlans).
I have set up the vpc domain 1 and configured the peer-keepalive source, destination and vrf. All seemed fine.
So I had a connection between those Switches and could ping each way in my SVI.
In the moment i set the command vpc peer-link in the port-channel the vlans in the trunk went on err-disable and I lost connection.
SWITCH# sh int trunk
Port          Native  Status        Port
              Vlan                  Channel
Eth1/1        1       trnk-bndl     Po100
Eth1/17       1       trnk-bndl     Po100
Po100         1       trunking      --
Port          Vlans Allowed on Trunk
Eth1/1        410-412
Eth1/17       410-412
Po100         410-412
Port          Vlans Err-disabled on Trunk
Eth1/1        410-412
Eth1/17       410-412
Po100         410-412
I have the following message in the log:
2012 Jun 21 09:42:31 SWITCH %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 4
10-412 on Interface port-channel100 are being suspended. (Reason: peer-keepalive
not operational, peer never alive)
And I've seen this in debug vpc peer-keepalive
SWITCH(config-if)# 2012 Jun 21 11:58:46.742933 vpc: Added 3 vlans to loc cfg list
2012 Jun 21 11:58:46.743004 vpc: Saving the MCT [1] context in PSS
2012 Jun 21 11:58:46.747084 vpc: Vlans [410-412] in Error vlan list for MCT
Anybody some Ideas how to fix this?
I use this NX-OS: n5000-uk9.5.1.3.N2.1.bin
I am pretty sure, the config is fine... but somewhere I am missing something.
Thanks Chris
Correct Answer by Oleksandr Nesterov about 4 years 9 months ago
Hi Christoph
I think Reza wanted to say that we can't see interfaces that act as endpoints for peer keep-alive link.
Also here is VPC operations guide which stands that mgmt port is recommended solution for keep-alive link:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/operations/n5k_L3_w_vpc_5500platform.html#wp999392
HTH,
Alex
Overall Rating: 5 (3 ratings)
Reza Sharifi Thu, 06/21/2012 - 06:38
  • Cisco Designated VIP,
    2017 LAN
Can you post your config?
christoph.brunner Thu, 06/21/2012 - 07:21
feature interface-vlan
feature lacp
feature vpc
vrf context VPC-PEER
vrf context management
  ip route 0.0.0.0/0 192.168.10.1
vlan 1
vlan 410
  name VPC-PEER
vlan 411
  name VMotion
vlan 412
  name Storage
vpc domain 1
  role priority 100
  system-priority 100
  peer-keepalive destination 192.168.0.2 source 192.168.0.1 vrf VPC-PEER
  peer-config-check-bypass
  auto-recovery
interface port-channel100
  description VPC-Peer-Link
  switchport mode trunk
  switchport trunk allowed vlan 410-412
  spanning-tree port type network
  spanning-tree guard loop
  speed 10000
  vpc peer-link
interface Ethernet1/1
  description SWITCH2,Eth1/1
  channel-group 100 mode active
interface Ethernet1/17
  description SWITCH2,Eth1/17
interface mgmt0
  description Mgmt-Vlan
  ip address 192.168.10.25/24
I figured out that I can set up the VCP-Peer over the mgmt0 Interface. Then I can switch the configuration to my SVI and it works. But after a reload of the whole system, I have the same problem.
I guess the peer must go over mgmt0
Reza Sharifi Thu, 06/21/2012 - 08:11
    2017 LAN
I don't see your VPC domain config:
Have a look at this sample config and make the necessary changes to reflect your environment
! enable features
feature vpc
feature lacp
! Define a vrf for the keepalive traffic
vrf context vpc-ka
! Configure vpc domain - this switch (in the vpc-ka vrf) is 10.0.0.1; its partner is 10.0.0.2
vpc domain 1
role priority 100
system-priority 100
peer-keeplive destination 10.0.0.2 source 10.0.0.1 vrf vpc-ka
peer-gateway
! Configure the VPC keepalive interface (port-channel or single interface)
interface Ethernet 1/1
vrf member vpc-ka
ip address 10.0.0.1/31
no shutdown
! Configure the layer 2 interchassis peer-link
interface Ethernet 2/1
channel-group 1 force mode active
no shutdown
interface Ethernet 3/1
no shutdown
switchport
switchport trunk allowed vlan a,b,c
vpc peer-link
spanning-tree port type normal
no shut
! Configure the actual vPC facing the downstream device
! For the 'vpc  xxx' command:
! 1) use a different xxx for each port-channel to a downstream device;
! 2) ensure that the 'partner' port-channel on DST2 uses the same xxx;
! 3) xxx has nothing to do with the vpc domain number configured earlier.
interface Ethernet 2/8
channel-group 2 force mode active
no shut
interface Ethernet 3/8
no shut
interface port-channel2
switchport
vpc 102
no shut
Correct Answer
Oleksandr Nesterov Thu, 06/21/2012 - 08:48
  • Cisco Employee,
  • Events Top Contributors,
    Cisco, 2014
Hi Christoph
HTH,
Alex
christoph.brunner Fri, 06/22/2012 - 02:01
Hey
I've done it now with the recommended solution. I am still confused why it doesn't work with the SVI, as I had my own VRF. I think the SVI must not run on the actuall VPC Peer Link. I think thats the point.
Related Content
