MOH Live Feed - FXO to 3.5mm
shiblyibrahim
Level 3
Level 3
Guys I need help. Ill be really grateful.
I am trying to make MoH Live feed work connecting an FXO port to an iPod or any device.
But for some reason we tried using a device from ebay which is this http://www.ebay.co.uk/itm/3-5MM-AUDIO-PLUG-TO-RJ11-CAT5-CABLE-EXTENDER-DEVICE-50M-/330334917421?pt=UK_Sound_Vision_Other&hash=item4ce97ed32d
Does anyone know how to make it work.
Please rate the post Shibly Ibrahim
Jaime Valencia
Using an analog E&M port as the live-feed MOH interface requires the  minimum number of external components. You connect a line-level audio  feed (standard audio jack) directly to pins 3 and 6 of an E&M RJ-45  connector. The E&M voice interface card (VIC) has a built-in audio  transformer that provides appropriate electrical isolation for the  external audio source. An audio connection on an E&M port does not  require loop-current. The signal immediate and auto-cut-through commands disable E&M signaling on  this voice port. A G.711 audio packet stream is generated by a digital  signal processor (DSP) on the E&M port.
If you use an FXO port as the live-feed MOH interface, connect the MOH  source to the FXO port using a MOD-SC cable if the MOH source has a  different connector than the FXO RJ-11 connector. MOH from a live feed  is supported on the VIC2-2FXO, VIC2-4FXO, EM-HDA-3FXS/4FXO, EM-HDA-6FXO,  and EM2-HDA-4FXO.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1010511
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thanks Java.
