Traversal and non-traversal calls
Answered Question
Jun 21st, 2012
Can somebody explain in simple words what are traversal and non-traversal calls?, what is the difference? And also Does the VCS control below need traversal licenses?,
CTI-VCS-CONTRL-K9
VCS Control
Thanks in advance.
Correct Answer by Tomonori Taniguchi about 5 years 1 month ago
If you have two C-series Endpoint (i.e. CTS-SX20) both registered on VCS Control and also Endpoint able to reach out directly each other (has routing), then in general the call will treat as non-traversal call, so no traversal license will be required.
However if those Endpoint calling each other but using different protocol (i.e. one Endpoint registered on VCS Control only with H323 and other Endpoint registered on VCS only with SIP), or different IP version (i.e one with IPv6 and other with IPv4 registration), then VCS Control will remain the media routing in order to handle such interworking scenario which will require traversal call license.
Overall Rating: 5 (3 ratings)
Tomonori Taniguchi Thu, 06/21/2012 - 07:42
  • Cisco Employee,
On VCS Control…,
Non-Traversal Call: VCS only involve and take call signaling
Traversal Call: VCS involve both call signaling and media routing.
- Traversal Call between VCS-Expressway
- IPv4/IPv6 Interworking Call
- SIP/H323 Interworking Call
- B2BU Call (i.e. MS Lync integration)
etc.
Mahesh Kumar Sat, 02/25/2017 - 08:58
Will a SIP to SIP(P2P) call between Jabber and Endpoint disconnect when VCS loss network connection or failure? (both registered to same VCS)
Will a SIP to SIP(P2P)call between endpoint and endpoint disconnect when VCS loss network connection or failure?  (both registered to same VCS)
Will a SIP to SIP (P2P) call between endpoint and endpoint disconnect when VCS loss network connection or failure? (one endpoint registered to VCSc and other is external endpoint call travel thru VCSe)
Tomonori Taniguchi Sun, 02/26/2017 - 02:29
  • Cisco Employee,
All scenario, call will disconnect either next SIP transaction or call TTL.
Mahesh Kumar Thu, 05/25/2017 - 14:00
Thanks All!
1. How to know or calculate the required traversal and non-traversal license?
2. How the VCS calculate the traversal and non-traversal license utilization in percentage(%) in status page?
Patrick Sparkman Thu, 05/25/2017 - 14:23
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 TelePresence
Every call that goes through the VCS will consume either a traversal or non-traversal license, the type of license the call consumes depends on how the call is made and if the media (audio and video) is routed through the VCS, take a look at VCS Traversal and Non-Traversal Call License Usage.
The percentages on the status page display the current and peak license usage based on the available licenses for each license type installed on the VCS.
Patrick Sparkman Mon, 02/27/2017 - 15:14
    2017 TelePresence
As Tomonori has mentioned, if the VCS loses network connectivity, all calls that are either registered or simply route their call through that particular VCS will disconnect, this is because the VCS handles the signalling and in some cases the media between endpoints.
Mahesh Kumar Tue, 02/28/2017 - 05:57
what if we have cluster of five VCS and one VCS fails which had couple of active calls and registration.
I understood that only the Traversal call will drop when VCS fails since the media and signal flowing thru VCS and Non-Traversal call media would flow separate.
Patrick Sparkman Tue, 02/28/2017 - 06:18
    2017 TelePresence
The active calls on the VCS that fails will disconnect, if your DNS is setup correct, the endpoints will then register with another VCS in the cluster.
Mahesh Kumar Fri, 07/21/2017 - 10:04
In which scenarios rtp-media will flow thru the VCS?
When the rtp-media flows thru VCS will the video and audio quality degrade ?
In point to point call after signaling will the VCS continues to send signal between endpoints or will there be live check between VCS and endpoints?
Patrick Sparkman Fri, 07/21/2017 - 10:35
    2017 TelePresence
As long as one endpoint is registered to the VCS, signaling will always route through the VCS, and media will route through the VCS for all traversal calls.
Tomonori Taniguchi Thu, 06/21/2012 - 08:00
  • Cisco Employee,
On VCS Expressway (just for additional reference)...,
- SIP: call between SIP UA and both SIP UA’s have same sip contact address and source IP address
- SIP: call handle as ICE call
etc.
- SIP: Call between SIP UA and one or both of SIP UA’s sip contact address differs from source IP address
- H323: Call between H.323 Endpoint registered on VCS-E with either ASSENT or H.460 traversal capability.
etc.
jacinto1m Thu, 06/21/2012 - 08:04
If I have a VCS control and the call is between two telepresence end points:
CTS-SX20-PHD12X-K9SX20 Quick Set   HD  NPP    12xPHDCam  1 mic  remote cntrl
Do I need a traversal license?
Correct Answer
Tomonori Taniguchi Thu, 06/21/2012 - 08:13
  • Cisco Employee,
Tomonori Taniguchi Thu, 06/21/2012 - 17:13
  • Cisco Employee,
Please note currently VCS Control ship with 100 traversal calls license as package. (This specification may change but as of today that is how packaging it).
RICHARD MESSINGER Mon, 10/29/2012 - 11:53
Which is used when a endpoint is registered to a VCSc and the call is going to a Video phone or other audio endpoint that is registered to a Call Manager and we have a SIP trunk between the VCSc and the Call Manager?
I am guessing it would be a Traversel license seat.
gubadman Mon, 10/29/2012 - 12:11
  • Cisco Employee,
It depends a lot on set up. In our test labs they are usually non-traversal as the VCS is not taking media, just the signalling.
Guy
Tomonori Taniguchi Mon, 10/29/2012 - 21:37
  • Cisco Employee,
> Which is used when an endpoint is registered to a VCSc and the call is going to a Video phone or other audio endpoint that is registered to a Call Manager and we have a SIP trunk between the VCSc and the Call Manager?
As Guy mention, this is very depend on configuration but main factor is search rule and priority.
VCS always try to setup the call with native call protocol first then fall back to interworking call but this will be following search rule priority as well.
If call establish via UCM (over SIP trunk), then call most probably establish as non-traversal call unless encryption policy is enabled on VCS (then call will go through B2BUA on VCS and treat as traversal call).
If call establish with Endpoint on VCS, then it depend on configuration and far end device registration protocol.
Dany Daoud Fri, 02/01/2013 - 13:35
If you have 0 non-traversal license will VC calls work for instance using jabber ?
Tomonori Taniguchi Fri, 02/01/2013 - 14:28
  • Cisco Employee,
One VCS Expressway, VCS will use traversal call license to handle non-traversal call, if required.
For example, VCS-E has no non-traversal call license or already use all installed non-traversal call license with
existing active call, the new incoming non-traversal call will handle by consuming traversal call license (instead of disconnecting it because of non-traversal call license availability).
Please note, this is not true on VCS Control.
VCS Control will not handle non-traversal call by using traversal call license.
