06-21-2012 06:50 PM
Hi!
In the CLI documentation for the SG 300 Series, it shows sh ip route rip as a command. I have installed the latest firmware and that command is no longer available. Does the SG300 series support RIP?
Thanks!
Richard S.
Solved! Go to Solution.
06-21-2012 08:28 PM
Hello Richard,
My name is David Aguilar, and I am an engineer with the Cisco Small Business Center. Thanks for writing.
The SG300 Series does not support RIP. Only static routes (maximum of 32) are supported. However, the SG500X models support the RIP version 2 dynamic routing protocol.
In regards to the new Sx300 firmware, it did add a number of impressive security features including IP ARP inspection, DHCP snooping, and SSD encryption.
All the best,
-David Aguilar
Cisco Small Business Support Center
06-21-2012 08:28 PM
Hello Richard,
All the best,
-David Aguilar
07-06-2012 12:23 PM
can I ask you where can I find new 1.2.5 firmware verison? I was unable to find it.
Thank you!
Best wishes,
Marko
07-06-2012 12:50 PM
Marko,
The 1.2.5.70 firmware has been pulled by the business unit. Please continue to use the 1.1.2.0 firmware
07-06-2012 12:51 PM
I knew it was too good to last... Will it be added back?
07-06-2012 12:58 PM
Marko, please follow this post for updates;
https://supportforums.cisco.com/docs/DOC-25157
07-06-2012 01:01 PM
Thank you!
Best wishes,
Marko
02-14-2018 02:10 AM
Does Cisco SG300-28 support Dynamic routing in L3 mode now ? I want to check because I can see there is an update in firmware.
