Warning message
ping delay
Jun 22nd, 2012
Hi Experts
i have 2 Servers connected to same cisco switch i3560 n same L2 VLAN, i ping from Server 1  to Server 2 i got delay 800ms?why is that ?how can i solve this issue?
thanks
jamil
Overall Rating: 4 (1 ratings)
John Blakley Fri, 06/22/2012 - 04:14
  • Purple, 4500 points or more
Jamil,
A few things to check would be:
1. Physical connections. Make 100% certain that you're full duplex on both switchports that you're connected to.
2. Check for errors on those interfaces.
3. Check processor utilization at the time that you're getting high latency. The switch could be overloaded.
Are they in the same subnet? I'm assuming so since you said same L2 vlan, but if you have 1 server's primary as 192.168.1.1 and that same server's secondary as 192.168.2.1 and you're pinging another server that's at 192.168.2.2, then the 1st server will source that address as 192.168.1.1 and may need to cross a l3 vlan. If that's the case, you may want to also trace to see if the path is truly taking what you think it should be.
John
Ibrahim Jamil Fri, 06/22/2012 - 09:01
Hi John
thanks for ur reply
yes, as i mentioned both in same L2 Domain
Server 1 :192.168.100.1
Server 2 :192.168.100.2
Switch SVI:192.168.100.3
no errors in the switchports where the servers connected also the duplex is full , cables are good Quality , switch cpu 1%
thanks
Jamil
glen.grant Fri, 06/22/2012 - 09:07
  Doubt its the switch , sounds like  the servers are busy .
