Custom "forward calls to" menu
Jun 22nd, 2012
I would like to add custom phone numbers to the  “Forward calls to” menu in Jabber for Windows 9.0.2. Now it display Voicemail, Mobile and Home number as default. Can I change what to be displayed somehow? If yes how and where?
At the moment we use UDS as search directory.
Please see attached screenshot.
Best regards
Kim
szelenka Fri, 06/29/2012 - 08:10
  • Cisco Employee,
There is the ability to forward calls to a New number, which is at the bottom of the list.
The system can specify numbers for:
Voicemail
MobilePhone
HomePhone
OtherPhone
New Number (External)
None
It's customizable in that you can forward a call to any number using the "New Number" option, and if you want to create a persistent forward you can update that in the Directory and it will show up in this menu as an option.
I don't recall off hand if UDS has an option for OtherPhone, but if it does you could use that field to create a persistent forward that always shows up in the list.
skirk1983 Mon, 12/10/2012 - 06:16
I have not configrued voicemail for several users. Can I somehow configure Jabber not to show the Voicemail in Forward Calls menu?
Best regards
Kristian
szelenka Mon, 12/10/2012 - 07:30
  • Cisco Employee,
There's no customization for that.  However, if you can open a TAC SR they should be able to open a defect to track this request.  IMO, if there is no voicemail configured for a user the system should be able to determine that and dynamically only display the forwarding options which are available to that user.
Related Content
