Spaces in the LDAP OU field
Answered Question
Jun 22nd, 2012
I'm running VPN SSL on an asa 5520 (V8.2.5) with LDAP authentication and everything works fine but now the AD people changed name in the groups and they added a " " "blank" in one of the fields so when I configured the group I get an error.
for example:
this works:
map-value memberOf CN=VPN_SSL_ABC,OU=External,OU=XXX,DC=ext,DC=local ABCPolicy
but this does not:
map-value memberOf CN=VPN_SSL_ABC,OU=External Group,OU=XXX,DC=ext,DC=local ABCPolicy
Is there any way to insert a space in the OU field?
thanks in advance
Giovanni
Correct Answer by Jennifer Halim about 4 years 7 months ago
Yes, just put quotes for the memberOf attribute as follows:
map-value memberOf "CN=VPN_SSL_ABC,OU=External Group,OU=XXX,DC=ext,DC=local" ABCPolicy
Overall Rating: 5 (2 ratings)
Correct Answer
Jennifer Halim Fri, 06/22/2012 - 07:25
