Warning message
MeetingPlace 8.5 - voice only Outlook plugin
Jun 22nd, 2012
Does anyone know how to remove the "Make this a voice and web meeting" question necessary to book a MeetingPlace meeting using the Outlook plugin?
It's confusing our users, they want to say No, but they need to check "Yes, create a new meeting" if they want it to actually be scheduled.  We don't have the web portion, we're audio only, I can't find anywhere to customize the prompt.
Thank you.
Karthik Sivaram Mon, 06/25/2012 - 08:59
  • Silver, 250 points or more
hi kdotten,
"Yes, create a new meeting" must be selected in order for this calendar
entry to become a MeetingPlace meeting. If you select this option and
populate all the required fields, the system will generate an e-mail
notification body to be sent out to invitees that will contain DIAL-IN
information for MeetingPlace and MeetingPlace meeting ID.
But to answer your question, it is not possible to remove this option
from the scheduling form.
Hope this helps!
Karthik
Related Content
