Warning message
PPTP VPN for select traffic and the rest using the internet.
Jun 22nd, 2012
I wish to connect my 2651XM to the internet and also have a PPTP VPN from the router to a commercial VPN provider (
184.22.182.11) with only select sites to use the VPN. I am having difficulty working out the routing.
10.0.0.0 is the LAN subnet
10.0.0.22 is a test pc
192.168.0.250 is the WAN ip (connecting in the back of an existing Router/Modem 192.168.0.254)
184.22.182.11 is the VPN Provider IP
8.8.8.8 is the server to test pinging against that should use the VPN tunnel and not the 'internet'
Relatively new to this whole thing..and some help would be greatly appreciated. Thanks
version 12.4
service config
service internal
hostname Core-Router
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 XXXXXXXXXXXXXXXXXXXXX
enable password XXXXXXXXXXXXXXX
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
no ip gratuitous-arps
ip cef
ip host server 192.168.0.10
ip host i7 192.168.0.22
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip multicast-routing
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vpdn enable
vpdn-group 1
request-dialin
  protocol pptp
  rotary-group 0
initiate-to ip 184.22.182.11
username xxxx password 0 xxxx
interface FastEthernet0/0
description INTERNET
ip address 192.168.0.250 255.255.255.0
ip nat outside
ip virtual-reassembly
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
description LAN
ip address 10.0.0.254 255.255.255.0
ip nat inside
speed auto
full-duplex
no mop enabled
interface Dialer0
mtu 1450
ip address negotiated
ip pim dense-mode
ip nat outside
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string 123
dialer vpdn
dialer-group 1
no cdp enable
ppp pfc local request
ppp pfc remote apply
ppp encrypt mppe auto
ppp chap hostname xxxx
ppp chap password 0 xxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.254    <-- ADSL modem/router LAN interface. Next hop router.
ip route 8.8.8.8 255.255.255.255 Dialer0  <--Test ping to 8.8.8.8 should go down the VPN
ip dns server
ip http server
no ip http secure-server
ip nat inside source route-map nat1 interface FastEthernet0/0 overload
access-list 10 permit 10.0.0.22  <--- This is simply a test pc to test the routing rules
dialer-list 1 protocol ip permit
snmp-server community public RO
route-map nat1 permit 10
match ip address 10
control-plane
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
handoko wiyanto Sun, 06/24/2012 - 05:08
hi there,
could you post the command show ip route after the pptp connection succeed?
regards,
