ISDN BR0 **ERROR** Temporary failure(0x29)
Jun 25th, 2012
I've got a router at a customer's site that uses ISDN as a backup line. For some reason, I was able to successfully make a call this morning, but then trying again right after that call, I get the following error message when I try to make an isdn test call interface bri 0:
*Mar  5 01:47:58.143: ISDN BR0 **ERROR**: host_disconnect_ack: Call rejected cause Temporary failure(0x29) call id 0x8007
The ISDN line is a standard Point to Multipoint ISDN line from the Deutsche Telekom here in Germany. I've already had a technician on-site to look at the line, calls in and out work perfectly fine, but the Cisco router can't make a test call properly. I've already replaced the router because the thing wouldn't initiate a call when the main SDSL line went down.
Can anyone give me a hint?
Here's debug isdn events and debug isdn q931:
router#isdn test call int bri 0 [testnumber]
router#
*Mar  5 02:00:38.379: ISDN BR0 EVENT: UserIdle: callid 0x800A received ISDN_CALL (0x0)
*Mar  5 02:00:38.379: ISDN BR0 EVENT: process_bri_call: call id 0x800A, called_number [testnumber], Guid C928DE00800D speed 64, call type DATA, bchan -1 clng_num none
*Mar  5 02:00:38.383: ISDN BR0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num [testnumber]
router#
*Mar  5 02:00:44.385: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Mar  5 02:00:44.389: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x800A calltype 1 HOST_DISCONNECT_ACK
*Mar  5 02:00:44.389: ISDN BR0 **ERROR**: host_disconnect_ack: Call rejected cause Temporary failure(0x29) call id 0x800A
router#
and here's the relevant config data:
router#show run int bri0
Building configuration...
Current configuration : 251 bytes
interface BRI0
description Dial Backup Interface
bandwidth 128
no ip address
encapsulation ppp
dialer pool-member 2
isdn switch-type basic-net3
isdn twait-disable
isdn point-to-point-setup
ppp authentication chap callin
ppp multilink
end
gs01-kempten#show run int dia2
Current configuration : 420 bytes
interface Dialer2
bandwidth 128
ip unnumbered Loopback0
ip access-group 120 out
encapsulation ppp
load-interval 30
dialer pool 2
dialer string 0[testnumber]
dialer string [testnumber]
dialer watch-group 1
dialer-group 2
ppp chap refuse
ppp pap sent-username [email protected] password pass
ppp ipcp dns request accept
ppp multilink
no cdp enable
end
dialer watch-list 1 ip [watched IP] 255.255.255.255
dialer watch-list 1 delay route-check initial 600
dialer watch-list 1 delay connect 180
dialer watch-list 1 delay disconnect 120
access-list 120 remark "deny voice via Backup"
access-list 120 deny   ip any [voice net] 0.0.255.255
access-list 120 permit ip any any
We have this exact configuration running perfectly in dozens of other locations, so I really don't know what the deal is here.
michael.hutt Mon, 06/25/2012 - 00:47
Here's the software version:
Cisco IOS Software, C870 Software (C870-ADVENTERPRISEK9-M), Version 15.1(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 16-Nov-10 04:45 by prod_rel_team
michael.hutt Mon, 06/25/2012 - 02:08
I turned on debug isdn q921 and found this:
*Mar  5 02:55:30.710: ISDN BR0 Q921: User TX -> IDREQ ri=45637 ai=127
*Mar  5 02:55:32.710: ISDN BR0 Q921: User TX -> IDREQ ri=54934 ai=127
*Mar  5 02:55:34.711: ISDN BR0 Q921: User TX -> IDREQ ri=16375 ai=127
Apparently the router is attempting to establish Layer 2, and is sending IDREQs to the ISDN switch in the CO, but the switch isn't responding. I've opened up another ticket with the Deutsche Telekom with the hope that I can solve this problem with them. Has anyone else experienced this?
michael.hutt Wed, 06/27/2012 - 01:19
An update: Yesterday morning I could make all kinds of isdn test calls, but then suddenly it started up with the IDREQ nonsense again, ending in the same error.
Do I need to replace the router a second time?
michael.hutt Sat, 06/30/2012 - 03:48
So I found the problem... It's a bug in the IOS software 15.1(3)t. I downgraded one of the routers to 12.4(6)T6 and it can now dial out just fine.
The problem here is that I upgraded the other router to 15.1(3)t because the customer wanted to upgrade the ADSL line to 16 Megabit ADSL2+, and 12.4(6)T6 contains an ADSL Modem firmware that's not compatible with ASDL2+ @ 16 Megabits, so now I need to find a way to downgrade the router's firmware while keeping the ADSL Modem firmware.
paolo bevilacqua Sat, 06/30/2012 - 05:55
  • Hall of Fame,
    Founding Member
You can update ADSL firmware indipendently from IOS.
Sandeep Choudhary Mon, 07/02/2012 - 05:15
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
As far as I recall it's a link error. Do you have a green light flicking on slot. Can you ISP ring your router ? It could be a line error. If the line is OK, check your PI/VCI settings against your ISPs settings.
If that is Ok, check how you are authenticating.
If using chap, you should have the line > ppp authentication chap callin
please rate if it helps.
Related Content
