%ADJ-SP-3-ILLEGALARGS on cisco 7204 router
Jun 26th, 2012
I have below mention log on my cisco router 7204.I check bug tool kit and even search this on google but didnt find any thing
UAE: %ADJ-SP-3-ILLEGALARGS: Illegal arguments - cannot derive adjacency
Below is the show version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICES-M), Version 12.2(33)SRC2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 18-Sep-08 01:49 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRC3, RELEASE SOFTWARE (fc1)
DST-CST1-BC4-MDF uptime is 1 year, 24 weeks, 1 day, 22 hours, 45 minutes
Uptime for this control processor is 1 year, 24 weeks, 1 day, 23 hours, 2 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 09:27:25 UAE Sat Jan 8 2011
System image file is "bootdisk:c7600rsp72043-advipservices-mz.122-33.SRC2.bin"
Last reload type: Normal Reload
Cisco CISCO7604 (M8500) processor (revision 2.0) with 851968K/65536K bytes of memory.
Processor board ID FOX1238G65H
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from power-on
574 Virtual Ethernet interfaces
50 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
nkarpysh Tue, 06/26/2012 - 00:44
  • Cisco Employee,
Hello Asim,
It seems like we are hitting the below bug.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu36337
This bug is fixed in 12.2(33)SRD1 and later versions of IOS. The error
message occurs when the netflow process tries to gather information on an
adjacency that has gone away and should have no service/performance impact
aside from the message itself. If you'd like the fixes for it, you'll need
to upgrade the code on your device.
*Please rate if it helped
Nik
