IP V4 to V6 Migration
Jun 26th, 2012
Hi Experts,
i want help to migrate all the public ip addresses to ipv6 .
What are the thinks i should taken care??
Vipin                  .
Overall Rating: 2 (1 ratings)
sean_evershed Tue, 06/26/2012 - 07:23
  • Gold, 750 points or more
One thing to consider is routing.
If the public IP addresses are hosted on an ASA firewall then this device does not as yet support dynamic IPv6 routing.
Therefore if you want to route to the IPv6 addresses of these devices from within your internal network you will need to inject a static route into your routing table.
Cheers
Sean
vipinrajrc Wed, 06/27/2012 - 00:41
What we are going to do is one to one maping in our edge router..
Thanks and Regards,
Vipin
vipinrajrc Wed, 06/27/2012 - 22:14
Hi experts..
I need to give our servers with IPV6 IP address. curretly all the servers are NATed with public IPs.
We want to these public IPs to IPv6 addresses.. any idea?
we are having a setup as.. switches--Firewall--Router--ISP
Kindly suggest u r valid opinions.
Thanks and Regards,
Vipin
sean_evershed Thu, 06/28/2012 - 06:12
So do you have a pool of global IPv6 addresses?
If so assign these addresses to your servers as required.
Are you plannig to keep your IPv4 addresses? If so you can run dual stack IPv4/IPv6 on these servers.
