Warning message
ACE 4710 - SSL issues 2 ViPS
Answered Question
Well I have struggled with our new ACE over the last few weeks but I think I am on my last issue
Currently have all inbound SSL termination working for *.english.ca
which uses a VIP of 192.168.10.10
but
I also need to terminate all inbound SSL connections for *.french.ca
which needs to use VIP 192.168.10.20
Right now all connections still appear to be going thru the 192.168.10.10 VIP when I look at service policy hitcounts.
Here is my config
class-map match-all english
   2 match virtual-address 192.168.10.10 255.255.255.224 tcp eq https
class-map match-all french
   2 match virtual-address 192.168.10.20 255.255.255.224 tcp eq https
policy-map multi-match vip
  class english
    loadbalance vip inservice
    loadbalance policy english
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 500
    ssl-proxy server english
  class french
    loadbalance policy french
    nat dynamic 2 vlan 500
    ssl-proxy server french
interface vlan 500
  description xxxxxxx
  ip address 192.168.10.2 255.255.255.224
  access-group input 101
  nat-pool 2 192.168.10.20 192.168.10.20 netmask 255.255.255.255 pat
  nat-pool 1 192.168.10.10 192.168.10.20 netmask 255.255.255.255 pat
  service-policy input vip
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  no shutdown
Sh service-policy summary shows that no matter what...all ssl connections are hitting against the english vip
service-policy: vip
Class                                  VIP                                      Prot  Port        VLAN          State    Curr Conns   Hit Count  Conns Drop
english                             204.101.28.164                            tcp   eq 443      1,500         IN-SRVC           0          11          0
french                              204.101.28.166                            tcp   eq 443      1,500         IN-SRVC           0           0          0
Surely I must be able to run multiple VIPS ?
Cheers
Dave
Correct Answer by Cesar Roque about 5 years 1 month ago
Hello Dave,
Try changing the match statements, it should look like this:
   2 match virtual-address 192.168.10.10  tcp eq https
   2 match virtual-address 192.168.10.20  tcp eq https
Cesar R
Overall Rating: 5 (1 ratings)
Correct Answer
Cesar Roque Tue, 06/26/2012 - 11:26
  • Bronze, 100 points or more
Hello Dave,
Cesar R
ajayku2 Tue, 06/26/2012 - 11:43
  • Cisco Employee,
when you use a mask you ideally end up taking the entire subnet in this case you used the range:
191.166.10.1 - 191.166.10.30  <<< 192.168.10.10 255.255.255.224 >>>>
Thats the reason for the trouble never use mask for the vip.
regards,
Ajay Kumar
Related Content
