Warning message
CUCM 4.3.2 and SRTP
Jun 26th, 2012
Hi there
please i need an help and information about my case , i really didn't know where to post this problem .
I'm a CCVP certified , here at my work they asked me to implement security in a Call Manager 4.3.2 enviroment.
Do u know if Cisco still supports it in case i need help and where can i buy the Cisco token usb key needed to create the CTL file ? or u know please who can i contact for these kind of informations?
Thank u guys
greetings from Italy
Antonio Scilimati
Overall Rating: 5 (3 ratings)
Jaime Valencia Tue, 06/26/2012 - 07:41
  • Cisco Employee,
  • Hall of Fame,
    2011
AFAIK the tokens are the same so you shoud stil be able to buy them.
4.3 is still supported
End-of-Sale and End-of-Life Announcement for the  Cisco Unified Communications Manager Version 4.3
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/vcallcon/ps556/end_of_life_notice_c51-612453.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Rob Huffman Tue, 06/26/2012 - 07:42
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Antonio,
CUCM 4.3 is still supported (see below);
Table 1. End-of-Life Milestones and Dates for the Cisco Unified Communications Manager Version 4.3
Milestone
Definition
Date
End-of-Life Announcement Date
The date the document that announces the end of sale and end of life of a product is distributed to the general public.
July 27, 2010
End-of-Sale Date
The last date to order the product through Cisco point-of-sale mechanisms. The product is no longer for sale after this date.
January 25, 2011
Last Ship Date:App. SW
The  last-possible ship date that can be requested of Cisco and/or its  contract manufacturers. Actual ship date is dependent on lead time.
April 25, 2011
End of SW Maintenance Releases Date:App. SW
The  last date that Cisco Engineering may release any final software  maintenance releases or bug fixes. After this date, Cisco Engineering  will no longer develop, repair, maintain, or test the product software.
January 25, 2012
End of New Service Attachment Date:App. SW
For  equipment and software that is not covered by a service-and-support  contract, this is the last date to order a new service-and-support  contract or add the equipment and/or software to an existing  service-and-support contract.
January 25, 2012
End of Service Contract Renewal Date:App. SW
The last date to extend or renew a service contract for the product.
April 22, 2013
Last Date of Support:App. SW
The  last date to receive service and support for the product. After this  date, all support services for the product are unavailable, and the  product becomes obsolete.
January 31, 2014
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/end_of_life_notice_c51-612453.html
Here is the Security guide for CCM 4.2, i don't believe there is a separate one for 4.3;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/4_2_3/sec423.html
You should still be able to purchase the tokens ...check out this part#;
KEY-CCM-ADMIN-K9=
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Antonio Scilimati Tue, 06/26/2012 - 12:31
Hi Rob
thank u so much for the answer , i'm sure to solve my case here at my work
Bye bye
Antonio
Antonio Scilimati Tue, 06/26/2012 - 12:52
Hi again guys,
regarding configuring security in a CUCM 4 scenario, it is almost clear but do you know how many cisco usb token do i need for configure a CTL file? becouse this aspect is not so clear
see u guys
Antonio
Rob Huffman Tue, 06/26/2012 - 13:22
  • Hall of Fame,
    Founding Member
Hi Antonio,
You will need a minimum of 2 etokens
Caution You need a minimum of two security tokens the first time that you configure the
client. Do not insert the tokens until the application prompts you to do so. If you
have two USB ports on the workstation or server, do not insert two security tokens
at the same time.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/4_2_3/secuauth.pdf
I think this thread is a "must" read
http://www.gossamer-threads.com/lists/cisco/voip/146498
Cheers!
Rob
Antonio Scilimati Tue, 06/26/2012 - 23:02
Great Rob
you are very gentle , l'll pay attention to what your wrote and to the links you posted.
Very interesting , thanks again
Antonio
Rob Huffman Wed, 06/27/2012 - 06:21
  • Hall of Fame,
    Founding Member
Hi Antonio,
You are most welcome my friend
Cheers!
Rob
Related Content
