Warning message
VCS OpenSSL commands not working
Jun 26th, 2012
I am following this document to create a CSR for the certificates
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Certificate_Creation_and_Use_Deployment_Guide.pdf
The openssl commands to create the certificate is failing on my machine.
openssl req –new –key privatekey.pem –config openssl_vcs.cfg –out certcsr.der -outform DER
I am getting a fail on the syntax at the last 'certcsr.der' it is telling me that .der is not a valid syntax.
Is this a mistake on the docs, or is there something I have missed?
See the attached pic for where it fails.
noelger Thu, 05/02/2013 - 12:06
Have you tried adding the option -sha1 on the end of your command line?
Cheers,
Neal
