ping request failure.
dipak3254176
i have a branch located in one of the regional location. To connect my branch with my company network. i have taken mpls line from our service provider.
In my branch office i have installed a layer 3 switch. Since we want to segregate my lan. we have created a vlan in l3 switch named vlan 10. i am facing a problem to connect my vlan host to company network.
Switch configuration is below.
vlan 10 ip 172.16.10.1 255.255.254.0
Default route 0.0.0.0 0.0.0.0 192.168.9.1
port Fa0/1 ip 192.168.0.250/24- connecting to 192.168.9.1/24(ISP Router)
Host in vlan 10 ip 172.16.10.10 255.255.254.0
From switch i can able to ping company network host (172.16.0.11).
The ping request from 172.16.10.10 is failed to get response from 172.16.0.1
My firewall is NETASQ
On firewall we can see a log like icmp block to address 192.168.9.1.
Since ping request is generated by my host computer(172.16.10.10) and reply is going to 192.168.9.1(which is MPLS line from ISP). we cannot able to get ping response and firewall block the reply to be send
In  NETASQ firewall there in no such option to apply IPS as filter base policy.
Attaching network Diagram for the same
Kindly Suggest.
Your response is highly appreciated.
6 Replies 6
Giuseppe Larosa
Hello Dipak,
they are not in the same IP subnet routing is broken, port fas0/1 should have ip address 192.168.9.250/24
Hope to help
Giuseppe
Sorry for creating confusion
port Fa0/1 ip 192.168.9.250/24- connecting to 192.168.9.1/24(ISP Router)
which routes do you see on L3 switch that you have on Branch Office?
"show ip route "
C    192.168.9.0/24 is directly connected, FastEthernet0/47
C    172.16.10.0/23 is directly connected, Vlan 10
S*   0.0.0.0/0 [1/0] via 192.168.9.1
Ok. thats good as per what you said earlier. I just wanted to make it sure. So SP is using static routing for VRF.
On the firewall have you allowed the subnet 172.16.10.0/23 from outside to communitcate to inside? And Are you able to ping from 172.16.0.11 to 172.16.10.10 ??
Nandan Mathure
yes i have already allowed 172.16.10.0/23 on firewall. i cannot able to ping 172.16.10.10 and 172.16.10.1 from 172.16.0.11
