ASA 5505 to Juniper switch
Answered Question
Jun 26th, 2012
I am wondering if anyone is aware of any known issues connecting an ASA to a Juniper switch?
We have a remote site where we have an ASA 5505 installed set up running EzVPN.  We do not have not have control/access to the internet connection or the internal infrastructure.  We basically have an office within thier building.  Our ASA has one of thier external IP addresses and is connected to thier Juniper switch.  Our pc's/printers are patched to another Juniper switch which is uplinked to our ASA.  The issue we are having is that the connection is intermittently dropping where we cannot ping the pc's/printers at the remote site through the VPN tunnel but we are still able to ping the external IP address of our remote ASA.  The strange thing is that we cannot manage the ASA via SSH or ASDM using the outside interface but can ping it when this occurs.  For the most part the VPN tunnel does not drop when we check the sessions at the headend although it occassionally will.
Any ideas as to what could be causing this type of issue?
Thanks in advance.
Jeff
Correct Answer by manish arora about 5 years 3 weeks ago
The issue with the unable to reach ( ssh or https ) the External IP but still able to ping suggests a duplicate IP address assignment by your provider in that building. The arp expiration for the ASA causes you to losse SSH access but at the same time lets you ping the device holding that same IP, now when someone from behind the ASA initiates any external connection the ASA refreshes the ARP on the upstream device and everything starts to work normally.
Now, all above is what I am thinking , i might be wrong ;-). Please have your admin look for Mac address ( arp -cache ) when you firewall is not responding to SSH but only to ping and see if it matches your ASA external interface MAC.
Manish
Overall Rating: 5 (1 ratings)
Jennifer Halim Tue, 06/26/2012 - 18:29
  • Cisco Employee,
I would suggest that you configure keepalive so the VPN tunnel gets torn down if either side has lost connectivity.
The VPN session could have been up on the headend, but it could be down at the remote site, hence you are not able to manage it.
Do you have the ssh and http command on the outside interface to allow management of the ASA on its outside interface?
Lastly, since it's EzVPN, once the tunnel is down, the VPN tunnel needs to be initiated from the remote site.
Why don't you just configure Lan-to-Lan tunnel so both end could initiate the tunnel? assuming that the remote site has static external IP.
Jeff Nagel Tue, 06/26/2012 - 21:53
Thanks for the response.
I configured the VPN as a Lan-to-Lan tunnel a couple of hours ago and I am seeing the same symptoms as I did with the EzVPN.
I did verify that the http and ssh commands are on the outside interface to all management of the ASA on its outside interface.
I would imagine since we have an external static IP on the outside interface of the ASA we should be able to manage the device no matter what.
We even went so far as to swap out ASA's to rule out a hardware issue with the ASA.  At this point it seems that either the Juniper and ASA have some sort of compatibility issue or there is something else going on with the site's internal network causing the strange behavior.
Thanks.
Jeff Nagel Wed, 06/27/2012 - 10:21
Here is the config.
ASA Version 8.0(4)
hostname HC-5505
enable password xxxxxxxxxxxxx encrypted
passwd xxxxxxxxxx encrypted
names
name 10.7.16.0 Beaumont_Net
name 10.7.16.229 Camelot
name 10.7.16.46 Citrix10
name 10.7.16.147 Citrix2
name 10.32.2.192 ejctxweb01
name 10.32.2.134 ewjcx025
name 10.32.2.193 ewjcx028
name 10.32.2.194 ewjcx029
name 10.32.2.195 ewjcx030
name 10.32.2.196 ewjcx031
name 10.32.2.214 ewjcx032
name 10.7.16.160 Lycan
name 10.125.224.30 MSSCITRX01
name 10.126.0.45 MSSCITRX02
name 10.7.16.215 PrevIntranet
name 10.32.2.218 ewjcx034
name 10.32.2.197 ewjcx035
name 10.32.2.198 ewjcx036
name 10.32.2.215 ewjcx037
name 10.32.3.80 ewjfs004
name 10.7.48.204 excalibur
name 10.7.16.175 mercury
name 10.7.16.142 mordor
name 10.32.2.229 mordor4
name 10.101.28.175 peoplesoft
name 10.32.2.57 snsiis01
name 10.0.48.96 snsnas01
name 10.7.16.50 tarheel
name 10.7.112.175 vampire
interface Vlan1
nameif inside
security-level 100
ip address 10.127.35.129 255.255.255.192
interface Vlan2
nameif outside
security-level 0
ip address xx.xx.xx.14 255.255.255.240
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa804-k8.bin
ftp mode passive
clock timezone CDT -6
clock summer-time CDT recurring
dns server-group DefaultDNS
domain-name my_domain.com
object-group network SV_Local
description SV Local
network-object 10.127.35.128 255.255.255.192
object-group network SV_Remote
description SV_Remote
network-object host ewjcx025
network-object host ejctxweb01
network-object host ewjcx028
network-object host ewjcx029
network-object host ewjcx030
network-object host ewjcx031
network-object host ewjcx032
network-object host Citrix2
network-object host Camelot
network-object host Citrix10
network-object host snsnas01
network-object host 10.101.20.28
network-object host peoplesoft
network-object host MSSCITRX01
network-object host MSSCITRX02
network-object host 10.126.0.54
network-object host 10.30.16.23
network-object host 10.30.16.24
network-object host 10.32.2.108
network-object host 10.32.2.129
network-object host 10.32.2.135
network-object host ewjcx035
network-object host ewjcx036
network-object host ewjcx037
network-object host ewjcx034
network-object host mordor4
network-object host snsiis01
network-object host ewjfs004
network-object host vampire
network-object host 10.7.16.159
network-object host Lycan
network-object host mercury
network-object host PrevIntranet
network-object host tarheel
network-object host 10.7.17.44
network-object host 10.7.20.27
network-object host excalibur
network-object Beaumont_Net 255.255.240.0
network-object host 10.7.16.9
access-list outside_access_in extended permit ip any any
access-list outside_cryptomap extended permit ip object-group SV_Local object-group SV_Remote
access-list inside_nat0_outbound extended permit ip 10.127.35.128 255.255.255.192 object-group SV_Remote
pager lines 24
logging enable
logging timestamp
logging trap debugging
logging asdm informational
logging facility 22
logging host inside 10.7.20.27
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-61551.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication serial console LOCAL
aaa authentication http console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 outside
http Beaumont_Net 255.255.240.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set peer 204.44.160.161
crypto map outside_map0 1 set transform-set ESP-3DES-SHA
crypto map outside_map0 1 set security-association lifetime seconds 28800
crypto map outside_map0 1 set security-association lifetime kilobytes 4608000
crypto map outside_map0 interface outside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 65535
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh 10.127.35.128 255.255.255.192 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
management-access inside
dhcpd lease 28800
dhcpd address 10.127.35.140-10.127.35.150 inside
dhcpd dns vampire Camelot interface inside
dhcpd enable inside
vpnclient server xxx.xx.xxx.xxx
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup hc password xxxxxx
vpnclient username hc password xxxxxx
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 64.250.229.100 source outside
username xxxxxxxx password xxxxxxxx encrypted
username xxxxxxxx password xxxxxxxx encrypted privilege 15
tunnel-group xxx.xx.xxx.xxx type ipsec-l2l
tunnel-group xxx.xx.xxx.xxx ipsec-attributes
pre-shared-key x
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Correct Answer
manish arora Wed, 06/27/2012 - 12:35
  • Silver, 250 points or more
Manish
Jeff Nagel Fri, 06/29/2012 - 11:41
That was it!    The admin at the site gave me another external IP for the outside interface of our ASA and the connection has been stable for the last day.  With the new IP on our ASA I was able to ping the old IP so they obviously have something else on their network with that same IP.
Thanks for the help.
Jeff
Related Content
