Warning message
ACS 5 for Wireless Access
Jun 27th, 2012
We've got an ACS 5.1 virtual appliance for device administration tasks and now we want to authenticate wireless domain users, but only by it's username/password, without trusting any CA certificates from the AD (is it required an ACS certificate too?).
Maybe there are some steps I have missed but I cant' locate where is the problem:
  1. The ACS is connected against AD correctly, as people from administrator group access successfully to device admin.
  2. AAA Clients are defined (autonomous APs) matching radius protocol
  3. Policy elements > Authorization > Network Access, a new profile has been created to guaranteed the access to the network with all the combos in the default value
  4. A new Access Policy > Access Service has been created (WIFI) matching protocols EAP-TLS (I think this is the problem)
    1. Identity is set to AD1
    2. Authorization has a rule with compound condition, matching AD1 -> External Group -> Wireless group, and Authorization Profiles set to the one created in step 3.
This is the configuration of the AP with the neccesary commands:
aaa group server radius rad_eap
server a.b.c.d auth-port 1812 acct-port 1646
server a.b.c.d auth-port 1645 acct-port 1646
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default group rad_eap local
dot11 vlan-name WPA vlan 199
dot11 ssid LABREDES_CERT
   vlan 199
   authentication open eap eap_methods
   authentication network-eap eap_methods
   guest-mode
   mbssid guest-mode dtim-period 75
interface Dot11Radio0
  encryption vlan 199 mode ciphers tkip
We have spent some days and nothing seems to work but nothing appears in the ACS log, and a debug (radius, aaa authentication) in the AP only shows (AAA/BIND(0000014E): Bind i/f  )
jesus.pavon Fri, 06/29/2012 - 05:23
Hi again, the problem is almost reolved.
Now the problem is with machine authentication, it does not works. We have checked options for machine authentication in the Active Directory Store, the Host lookup in Access Service Protocol, and we have 2 rules in the Access Service Authentication, first for System:Username starts with "host/" (without quotes) and the second for "Was machine authenticated" and Compound condition matchin username.
This way, it does not works, but when I don't pay attention in machine authentication it does works.
I have readed multiple "PEAP Machine Authentication" issues in the forum but nothing works in my case.
Any help please.
