Warning message
ASA Clientless VPN, RDP2 plugin not working properly.
Jun 27th, 2012
Model: ASA 5520
ASA: asa843-k8.bin
We are having an issue with the the ASA RDP2 plugin, it has been working correctly since the installation of the ASA 2 years ago.
1 month ago the functionality stopped working in IE activeX. I performed an upgrade of the ASA software in an attempt to fix, unfortunately this has not resolved the issue. Reimporting the plugin has not solved our issue either.
When using the Java client, there is a warning that -
"The terminal server disconnected before licence negotiation completed. Possible cause: terminal server could not issue a licence"
When a user clicks on a bookmark or types in a server name that is associated to the RDP2 plugin, the page timeouts and goes back to the home screen of the clientless SSL vpn.
Cheers
Chris
Jennifer Halim Thu, 06/28/2012 - 06:46
  • Cisco Employee,
Have you tried with the latest version of RDP plugin (rdp-plugin.120424.jar) relased in April 2012?
