Warning message
migration from asa 5505 to asa 5510
Jun 27th, 2012
my company has the asa 5505 working as the remote access vpn server. my company needs more licenses for vpn than the asa 5505 give it. because of my company purchased the asa 5510. i must migrate configuration from the asa 5505 to the asa 5510. i exported configuration file from asa 5505. i made the changes on them and imported them in the asa 5510. my asa5510 doesn't work. why? can we help me? i puted configuration files from asa 5505 and 5510
thanks
Jouni Forss Thu, 06/28/2012 - 02:47
For one I dont see any NAT configurations on your ASA5510 (Basic PAT and the NAT Exempt configuration for VPN)
Also you are using a global access-list that doesnt really allow any traffic other TFTP? Other traffic is probably getting blocked. Personally I avoid using global access list like a plague.
Also you seem to have made the ASA software jump from your old 8.2 to 8.4
This means that access-list and NAT configurations are way different from what you have been used to with software 8.2 on the ASA5505
- Jouni
goran ljubic Thu, 06/28/2012 - 03:15
can we help me. how configuring nat and acl for my vpn connection? thanks
Jouni Forss Thu, 06/28/2012 - 03:25
Looking at your old ASA 5505 8.2 software version configuration it seems you should do the following
First I would suggest starting of with access-list per interface and not a global access-list. I guess this is a matter of taste so its optional.
ACCESS-LIST CHANGES
no access-group global_access global
no access-list global_access extended permit udp user LOCAL\192.168.1.3 any any eq tftp
access-list INSIDE-IN remark Allow traffic from LAN
access-list INSIDE-IN permit ip 192.168.0.0 255.255.255.0 any
access-group INSIDE-IN in interface inside
NAT CONFIGURATIONS
- Basic PAT
object-group network PAT-SOURCE-NETWORKS
description Source networks for PAT
network-object 192.168.0.0 255.255.255.0
nat (inside,outside) after-auto source dynamic PAT-SOURCE-NETWORKS interface
- NAT exempt for VPN
object network VPN-POOL
description VPN Client pool
subnet 192.168.50.0 255.255.255.0
object network LAN-NETWORK
description LAN Network
subnet 192.168.0.0 255.255.255.0
nat (inside,outside) source static LAN-NETWORK LAN-NETWORK destination static VPN-POOL VPN-POOL
The above should get you started with basic config.
Please rate the post if it was helpful
- Jouni
goran ljubic Tue, 07/03/2012 - 01:31
i made config file for my asa 5510. what you thing about this file? can i start vpn connection and i change my asa 5505 with asa5510?
thanks
Result of the command: "show run"
: Saved
ASA Version 8.4(2)
hostname asa5510
domain-name dri.local
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 178.x.x.x 255.255.255.248
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.0.10 255.255.255.0
management-only
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
nat (inside,outside) source static LAN-NETWORK LAN-NETWORK destination static VPN-POOL VPN-POOLpager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool vpnadrese 192.168.50.1-192.168.50.100 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 178.x.x.178 1
route outside 0.0.0.0 0.0.0.0 178.x.x.177 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
action terminate
dynamic-access-policy-record dripolisa
aaa-server DRI protocol ldap
aaa-server DRI (inside) host 192.168.0.20
ldap-base-dn DC=dri,DC=local
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password *****
ldap-login-dn CN=dragan urukalo,OU=novisad,OU=sektor2,OU=REVIZIJA,DC=dri,DC=local
server-type microsoft
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
aaa authorization command LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.0.14-192.168.0.45 inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy drivpn internal
group-policy drivpn attributes
dns-server value 192.168.0.20 192.168.0.254
vpn-simultaneous-logins 10
vpn-idle-timeout 30
vpn-tunnel-protocol ikev1
default-domain value dri.local
username driadmin password AojCAMO/soZo8W.W encrypted privilege 15
tunnel-group drivpn type remote-access
tunnel-group drivpn general-attributes
address-pool vpnadrese
authentication-server-group DRI
default-group-policy drivpn
tunnel-group drivpn ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect http
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:5fe62ac95bd337424b6952baf1bb5e17
: end
goran ljubic Tue, 07/03/2012 - 02:34
i import configuration in asa and my running confiruation is
ASA Version 8.4(2)
hostname asa5510
names
nameif outside
security-level 0
nameif inside
security-level 100
management-only
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
access-list INSIDE-IN extended permit ip 192.168.0.0 255.255.255.0 any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu management 1500
arp timeout 14400
action terminate
ldap-scope subtree
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
vpn-idle-timeout 30
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect http
Cryptochecksum:4d4577afbf90588f7378df22c4d2d225
: end
what do you think?
goran ljubic Wed, 07/04/2012 - 09:57
i tryed that i use vpn client for connecting on my asa5510. i can logon but i can't access my resource on local network 192.168.0.0/24. my configuration on asa5510 is:
Result of the command: "show runn"
: Saved
ASA Version 8.4(2)
hostname asa5510
names
nameif outside
security-level 0
ip address 178.x.x.178 255.255.255.248
nameif inside
security-level 100
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
access-list INSIDE-IN extended permit tcp 192.168.0.0 255.255.255.0 any
access-list INSIDE-IN extended permit ip object VPN-POOL object LAN-NETWORK
access-list inside_access_out extended permit icmp object VPN-POOL object LAN-NETWORK echo-reply
pager lines 24
mtu outside 1500
mtu inside 1500
mtu management 1500
arp timeout 14400
access-group inside_access_out out interface inside
action terminate
ldap-scope subtree
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
vpn-idle-timeout 30
vpn-tunnel-protocol ikev1 l2tp-ipsec
authentication-server-group (inside) DRI
authentication-server-group (outside) DRI
authorization-server-group DRI
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect http
Cryptochecksum:38c7540e27ed313b9f3387ca49371753
: end
what i do? how i can access from my vpn client to local resources. i changed access rules but nothing
Jouni Forss Thu, 07/05/2012 - 02:20
I cant see the NAT Exempt configuration on your ASA configuration of the previous post
The configuration was this
I can see the "object" created but not the NAT configuration
- Jouni
Jouni Forss Thu, 07/05/2012 - 02:23
Also you dont need another access-list for the inside interface (the one in "out" direction")
I think by default the ASA lets through all traffic thats coming from VPN Client or L2L VPN hosts
So the VPN Client connections to LAN network should go through without changing any rules.
You can remove the
Because basically that access-list is already blocking all traffic BUT echo-reply from the VPN Client to the LAN network.
But as I said you also lack the NAT Exempt configuration
- Jouni
goran ljubic Thu, 07/05/2012 - 02:39
can you tell me how i make nat exemption on asa 8.4. i don't how?
command '
nat (inside,outside) source static LAN-NETWORK LAN-NETWORK destination static VPN-POOL VPN-POOL' doesn't the nat exemption?
i have this nat in my asdm
thank's
goran ljubic Thu, 07/05/2012 - 02:55
i putted command in my config file '
but i can't access to my local resources
: Saved
ASA Version 8.4(2)
hostname asa5510
names
nameif outside
security-level 0
nameif inside
security-level 100
management-only
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
access-list Split_Tunnel_List extended permit ip 192.168.0.0 255.255.255.0 any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu management 1500
arp timeout 14400
action terminate
ldap-scope subtree
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
vpn-idle-timeout 30
split-tunnel-network-list value Split_Tunnel_List
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect http
Cryptochecksum:db2d230f39f1c58de098465f2bc77a03
: end
Related Content
