Warning message
Ringback issues over CUCM MGCP GW vs E&M
Jun 28th, 2012
Dear friends,
I have a CUCM 8.6.2 with a MGCP gateway connected via interface E1 to the Siemens 300E. The Siemens 300E is connected to a anothers PBX's. My end point is a PBX E&M and the ringback isn't working properly.
Calls to another destinations is working properly, just calls to the E&M PBX aren't working ringback.
gw-bot-slpabx-1#
Jun 28 18:43:03.238: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x0009
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9FAA06800100820100A117020100020100800F44454C2E45202D20414C465245444F
        Calling Party Number i = 0x0081, '8516301'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '8717212'
Jun 28 18:43:03.342: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8009
Jun 28 18:43:03.626: ISDN Se0/0/1:15 Q931: RX <- FACILITY pd = 8  callref = 0x8009
        Facility i = 0x9FA40702026E8A810101
Jun 28 18:43:04.502: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
Jun 28 18:43:12.582: ISDN Se0/0/1:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8009
        Facility i = 0x9FAA068001008201008B0100A10F02027F5B0201553006820406040840
        Progress Ind i = 0x8081 - Call not end-to-end ISDN, may have in-band info
Jun 28 18:43:12.590: ISDN Se0/0/1:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8009
        Facility i = 0x9FAA068001008201008B0100A10F02027F6A0201553006820406040840
Jun 28 18:43:12.594: ISDN Se0/0/1:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8009
        Facility i = 0x9FAA068001008201008B0100A10F02027F790201553006820406040840
Jun 28 18:43:12.606: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8  callref = 0x8009
        Facility i = 0x9FAA068001008201008B0100A1140202AF00020102A10B0406532E4D455341020101
        Facility i = 0x9FAA068001008201008B0100A10F02027F880201553006820406040840
        Connected Number i = 0x0080, '7212'
Jun 28 18:43:12.610: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0009
gw-bot-slpabx-1#
Jun 28 18:43:28.502: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
Jun 28 18:43:30.366: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0009
        Cause i = 0x8090 - Normal call clearing
Jun 28 18:43:30.446: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x8009
Jun 28 18:43:30.470: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0009
Jefferson Islan... Thu, 06/28/2012 - 14:14
I think that when I enable the field "Setup non-ISDN Progress Indicator IE Enable" into the MGCP GW Port configuration, the issue should be fixed.
Someone already enabled the field Setup non-ISDN Progress Indicator IE Enable?
Related Content
