Warning message
link test mesh
Jun 28th, 2012
A link test on mesh network, why does the output shows no. of send & received packets at two different bandwidths rather than under one bandwidth.
i have attached an output for example here. in the output, why does the send & receive packet come under 54M & 48M?
Please help.Thanks.
Amjad Abdullah Sat, 06/30/2012 - 22:36
  • Red, 2250 points or more
You may have the sender send's at 48 Mbps and you send at 54 Mbps. There is nothing says that you should receive on same rate you send at.
To help you better, please explain if there is any problem that you want to fix.
Amjad
suthomas1 Tue, 07/03/2012 - 09:02
While testing we saw this different rate among multiple link test from various different ap's with the rates sometimes very disparate.
hence i was curious to know if it is some performance issue. Thank You
Amjad Abdullah Tue, 07/03/2012 - 09:13
i dont think it indicates any issue if you have no other pointer points to a performance degradation.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
