Warning message
UCCX 8.0.2 - error while handling the request
Jun 29th, 2012
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
My Customer have UCCX 8.0.2. He needed did change prompt and when He try to do upload the new script, appear the message: "error while handling the request". Any have idea who solve this problem?
Wilson
brian1mcc Fri, 06/29/2012 - 07:48
  • Silver, 250 points or more
I saw this before on 8.0.2, I had to delete the prompt/script/document and the upload it again (instead of overwriting it). I believe this was fixed in SU4.
Edit: this is the bug id - CSCtq23837 (unable to overwrite scripts) - resolved in 8.0(2) SU4
Brian
Please rate helpful posts
wilsonsant Mon, 07/02/2012 - 05:04
Hi Brian,
I opened a TAC and was identified the bug CSCts80098. The workaround did was disable/enable in service CDS and HDS. The fix is resolved in 8.0(2) S4 as You mentioned.
Thank You very much,
Wilson
Related Content
