Warning message
Problem with NTPv4 over IPv6
Jun 29th, 2012
Dear All,
When I was doing PoC for IPv6 transition, I had to work with NTPv4 for native IPv6. I am using 3825 running 12.4(24)T  adv enterprise.
As per Cisco documents NTPv4 is supported in 2 modes.
1. Client - Server.
2. Multicast.
I am presently interested in Client Server Mode
In this mode I configured Server with command. 'ntp master 2'
And on the client I configured:
ntp update-calendar
ntp server FD00:0:0:60::1 source Loopback0
Loopbacks of both server and client are reachable using OSPF.
But NTP remains unsynchronised forever.
Are there any known issues with NTPv4 over native IPv6 ?
fabios Fri, 08/24/2012 - 13:52
Hello Maulik,
I am running a 1921 in a production environment and the NTP config includes:
ntp update-calendar
ntp peer 192.168.128.3
ntp peer 192.168.128.5
ntp peer 192.168.128.10
ntp server 130.159.196.11
ntp server 2001:67C:288::128
(the router is running dual stack)
sh ntp associations
Gives:
  address         ref clock       st   when   poll reach  delay  offset   disp
+~192.168.128.3   158.43.192.66    2    710   1024   377  2.047   0.721 15.742
~192.168.128.5   .STEP.          16      -   1024     0  0.000   0.000 15937.
~192.168.128.10  192.168.128.7    4    862   1024   377  2.006  -1.532 19.759
~130.159.196.11  .STEP.          16      -   1024     0  0.000   0.000 15937.
*~2001:67C:288::128
                  195.220.94.163   2    703   1024   377 97.275   5.325 14.800
* sys.peer, # selected, + candidate, - outlyer, x falseticker, ~ configured
So apparently NTP works over native IPv6. I suppose connectivity (including access lists) is verified between the two devices .... try debug ntp packet and events.
Cheers
Fabio
maulik.parekh Fri, 08/24/2012 - 22:36
HI fabios,
Thanks for your reply.
I was able to synchronize NTP when running dual stack. It was just that when i used native IPv6, it didn't work.
Not a single ACL configured.
Strange thing is that when i use IPv6 on server, (i.e. Master) it gets reference clock as some public IPv4 address and says synchronised, whereas I never configured that.
Unfortunaltely we have dismanteled tht setup. If i get a chance again, I will surely post the configs.
Maulik
Related Content
