T.38 Fax with Transcoder
Answered Question
Jun 29th, 2012
Hi All,
Is it possible to do fax over IP which topology below?
Fax <<>> VG+transcoder <<<<<H323 G729>>>>>> 3rdParty PBX <<>> Fax
BR
WINAI
Correct Answer by Ayodeji oladipo... about 4 years 6 months ago
No, you cant use xcoders with T.38 fax. T.38 Fax does not use G729 or G711. It will use the bandwidth required for the fax e.g 14.4kbps fax rate. When the voice call is setup using either g729 or G711, the gateway will then switch to T.38 for fax transmission. So you can configure your voice gateway to use G729 to setup the call and then swicth over to T.38 for fax. You cant use a xocder and you dont need one.
Fax passthrough is a different fax mechanism.
In fax passthrough mode, gateways do not distinguish a fax call from a voice call. Fax communication between
the two fax machines is carried in its entirety in-band over a voice call. It only support g711.
NB: That there is a difference between faxpassthrough and fax-passthrough..
Fax Passthrough” can refers to the more specific passthrough transport method using an NSE switchover to pass faxes over G.711. “Fax pass-through” details a switchover to passthrough using the call control protocol.
Yes, for T.38 to work, your 3rd party vendor/device must support it.
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Overall Rating: 5 (1 ratings)
whenusayloveme Sat, 06/30/2012 - 05:26
Hi Jonathan,
-You mean we can use T.38 Fax protocol with transcoder involve right? (Transcoder do the transcoding between g711<>G729)
- But can't use fax passthrough isn't it?
- With T.38 scenario, 3rd party PBX must support also?
BR
Winai
Correct Answer
Ayodeji oladipo... Sat, 06/30/2012 - 16:06
