Port goes into error disable state 3750
Answered Question
Jun 30th, 2012
Can you please help with the following
We have a number of 3750 stacks used as access layer switches connecting Siemens VOIP phones and then a PC that connects to the phone.
For example if I plug PC A to the phone that connects to port 13 I pick up an IP addressand all works as predicted now if I plug in PC A to any other VOIP phone that connect to another port on the same switch it goes in error disable state ITs like the switch is holding my PC mac address and locks it down with the port which in my case is Gi2/0/13.
interface GigabitEthernet2/0/13
switchport access vlan 726
switchport mode access
switchport port-security maximum 10
network-policy 766
priority-queue out
mls qos trust dscp
spanning-tree portfast
Any help is much appreciated
Correct Answer by Karsten Iwen about 5 years 3 weeks ago
A switch will not be automatically blocked. But it will if more than X (with X=1 as you didn't specify any maximum in your new config) MAC-addresses are seen.
If you also want to protect your infrastructure against rougue switches you could also consider Rootguard or even BPDUguard.
Correct Answer by Leo Laohoo about 5 years 3 weeks ago
switchport port-security maximum 2
Something is missing here ...
Ok, you've enabled port-security and you've specified up to 2 MAC addresses allowed.  My question is what will the switch DO when three or more MAC addresses are learnt from a port?  Specifically, what ACTIONS did you specify the switchport to do when this event happens.  I believe the default is "error-disable".
Add the following lines and see what happens:
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
Overall Rating: 5 (2 ratings)
Karsten Iwen Sat, 06/30/2012 - 08:29
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
The disabling of the port is caused by port-security. The MAC is learned and kept by the switch for the port.
For these situations where PCs are roaming, you can put an idle-time on the port-security-entries:
Leo Laohoo Sat, 06/30/2012 - 20:31
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Your configuration doesn't have any Voice VLAN.
Can you please post the output to the command "sh interface status err"?
Zeeshan Siddiqui Sun, 07/01/2012 - 04:31
Hi Karsten,
Many Thanks for your response the new config will look like
network-policy 766
priority-queue out
mls qos trust dscp
The Phones work and do not reboot when move from one phone to another
Will the config above block a rogue switch if connected to the port ?
Correct Answer
Karsten Iwen Mon, 07/02/2012 - 14:12
Zeeshan Siddiqui Sun, 07/01/2012 - 05:06
Hi leolaohoo,
The switch port voice vlan command is replced by
network-policy 766
Pls see config for the policy below
network-policy profile 766
voice vlan 766
voice-signaling vlan 766 cos 3
voice-signaling vlan 766 dscp 24
Below is the output from a test phone
HS-1FB-C3K-1#sh int status err-disabled
Port      Name               Status       Reason               Err-disabled Vlans
Gi1/0/5                      err-disabled psecure-violation
HS-1FB-C3K-1#
HS-1FB-C3K-1#
Below is the original config I had on the ports
network-policy 766
priority-queue out
mls qos trust dscp
ITs like the switch holds the MAC address fixed to the switch port number when I plug in the same PC to another phone it goes to error disable
Kind Regards,
Zee
Correct Answer
Leo Laohoo Sun, 07/01/2012 - 15:26
  • Hall of Fame,
    2017 LAN, Wireless
Related Content
