CUCM6 UI Password Recovery
abdofares
We are facing a problem in our production CUCM 6.
After the power shutdown neither the Pub or Sub is doesn't work the Pub is asking for recovery disk "which is not available in our stock".
And the Sub is running but I couldn't access the cm administrator or the serviceability, he doesn't recognize the username or the password, I login to the sub CLI using ssh, and tried to recover the password using this command:
utils reset_ui_administrator_password
but it didn't work it give me this error:
admin:utils reset_ui_administrator_password
New password:
Confirm new password:
-------------------- utils reset_ui_administrator_password --------------------
Reset user interface password
eniccm
06/30/2012 16:54:30.538 | Update FAILED: code = 1, AUTHORIZATION FAILURE
Please advise
FARES
Message was edited by: Abdulmagiad Fares
Jonathan Schulenberg
You need to focus on getting the publisher back online. That command requires a database write operation on the publisher to succeed. You can download the recovery disk for your exact version from CCO. There have been sporadic reports that CCO downloads are down this weekend. If you run into this open a P1 TAC case; the engineer can post it to special file access for you.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b1f305.shtml
Please remember to rate helpful responses and identify helpful or correct answers.
