Remote Access VPN using Mutual Group Authentication ( CA certificate)
Jul 1st, 2012
Dear Experts,
In   my organization , we have Cisco ASA 5540 that is configured with the   remote access VPN profile. The Remote VPN is configured in such a way   that the user authentication will be through Microsoft LDAP ( AD   server).
Currently   the VPN client is using the Group Authentication method and we would   like to go for certificate based authentication (
Mutual Group Authentication) using CA server. Below are my queries regarding to the these migration.
1.Have anyone did Remote Access VPN with CA Server ?
2.Can i use the same AD server as CA server ?
3. What are configuration changes that required in ASA for the Remote VPN users to enroll the certificate with CA server ?
Kindly advice.
Shiji
Karsten Iwen Sun, 07/01/2012 - 07:48
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
I used it quite often before migrating to AnyConnect.
Yes, you can. But you shouldn't. For security-reasons it's better to make it a separate VM.
>3. What are configuration changes that required in ASA for the Remote VPN users to enroll the certificate with CA server?
The ASA-part is described here:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080930f21.shtml#asa1
s.aliyarukunju Wed, 07/04/2012 - 12:03
Thank you karsten for your help.
I will review and apply the configuration and update you.
