Can ping Internet but can't browse it
Hello
I'm experiencing problems with a Cisco 887M router. I have configured the same way I've done fozens of times but the users can't browse the internet. Everybody can ping public IP addresses, every user resolves URL but no one can't browse any website. The only time I found n issue like that I disabled the DNS forwarding under IP dns view default and it worked fine (it was on a UC500). Now I've done the same but the users can't browse the Internet. Any idea?
Thank you in advance for your help
DANi
17 Replies 17
smehrnia
Level 7
Level 7
Hi Daniel,
connection and dns wise, there must be no problem, it should be something blocking ur TCP/UDP ports, double check that. see if you can telnet over internet.
HTH,
Soroush.
Hope it Helps!
Soroush.
Hi Dan,
I think ur are not able to browse due as ur IPs are not able to resolve the DNS please follow below steps,
1)Connect the ISP link directly to single PC and configure the IP details provided by ISP.
2)Check if u are able to ping the gateway of ISP and browse
3)Change the DNS ip address (use public DNS for testing
  • 8.8.8.8
  • 8.8.4.4
  • 4.2.2.1
  • 4.2.2.2
4)IIf not resolved check the default route is pointed to proper IP
5)If not then co-ordinate with ISP for same might be their end issue.
the tests I've done froma PC on the customer network:
- ping 8.8.8.8 , OK
- ping www.google.es and other url. Always resolves the URL into a public IP and the pings response
- repeat the tests with a LAN fixed IP address or DHCP. Same results
- change DNS: 8.8.8..8 or ISP provided or even others. Same results
- obviously I can ping the default-gateway.
- I can start PPTP sessions to hosts on the outside with no problem and access remote servers via VPN
and the best one:
- I'm not on customer's site right now but I have remote Telnet to the router and teamviewer access to a PC that can't browse the Internet!!
What am i missing?
DAni
The current config:
version 15.1
no service pad
service password-encryption
hostname rtr1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
clock timezone CET 1 0
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 3:00
ip source-route
ip dhcp excluded-address 192.168.5.0 192.168.5.99
ip dhcp pool DATOS
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.1
   dns-server 8.8.8.8
ip cef
no ip domain lookup
no ipv6 cef
license udi pid CISCO887M-K9 sn xxxxx
archive
log config
  hidekeys
username xxxxx privilege 15 secret 5 x
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 2
interface Vlan1
ip address 192.168.5.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Vlan2
no ip address
pppoe-client dial-pool-number 1
interface Dialer0
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
fair-queue
ppp authentication chap pap callin
ppp chap hostname adslppp@telefonicanetpa
ppp chap password 7 13041301071C143A
ppp pap sent-username
adslppp@telefonicanetpa password 7 1416161800143A3B
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended NAT
permit ip 192.168.5.0 0.0.0.255 any
logging esm config
route-map NAT permit 10
match ip address NAT
Hi Daniel
Can you change DNS to 4.4.2.2  and test.
what is the default gateway for the user  and what IP address they get
paste the ouput of the following
show ip int brief
show ip nat translation
Its really strange that u have team viewer access but no browsing
What is the public wan ip as i dont see any in config and to which interface is it connected ?
Daniel,
If you can ping by name, DNS works fine. If you can ping a public address from your private hosts, natting is working fine. Is there any other equipment between a host and the router like a firewall or in front of the router that could be blocking it?
John
HTH, John *** Please rate all useful posts ***
I have tried with DNS 4.4.2.2 but we are unable to resolve URLs.
The IP addess the customer get is one from the pool 192.168.5.100 to 192.168.5.254 but now we are trying with 192.168.5.50, as you can see on the ip nat translations:
Daniel,
Couple of suggestion...
1. Try removing virtual reassembly command on both LAN and WAN interface and check.
2. Remove manual set MTU size from Dialer as it will be default to 1492 for PPP anyways. Alternatively you can try set it to 1500 and check if it works.
3. Can you do extendend traceroute to google.com with source port of 80 ( keep debug ip packets on) and share the results.
4. Repeat the above step, but this time with debug ip icmp on.
5. show ip nat translation
Sukanya
I have the same problem. I can ping from inside the router any site i.e www.yahoo.com. I can ping from the client side by domain name or by IP but I cannot browse. There is no any device in between like firewall and all PC's are connected directly to the switch including the 887 Router.
Router#sh run
Building configuration...
Current configuration : 1577 bytes
! Last configuration change at 15:35:29 UTC Mon Jul 2 2012
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 4 HrS.bFmfxShOxxsSI7lS/jQKCkRk1Fbc45HNxy8A1KE
no aaa new-model
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ162090XZ
controller VDSL 0
interface Ethernet0
no ip address
shutdown
no fair-queue
interface ATM0
no ip address
pvc 0/35
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip address 192.168.115.3 255.255.255.0
ip nat inside
no ip virtual-reassembly in <-----orignally enabled
interface Dialer0
ip nat outside
no ip virtual-reassembly in <-----originally enabled
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname user
ppp chap password pass
no ip http server
ip nat inside source list NAT-ACL interface Dialer0 overload
ip access-list extended NAT-ACL
permit ip 192.168.115.0 0.0.0.255 any
access-list 1 permit 192.168.115.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
password ..........
login
transport input all
end
Router#
I even tried different access-list like access-list 1 permit any but still not working. I have spent too much time pulling my hair and banging my head but I cant solve it. I hope somebody out there can solve solve my problem.
hi,
kindly insert these lines under your LAN and WAN interfaces and try again:
int vl1
int d0
ip mtu 1492
Thomas Torggler
hi daniel, did you check the clients proxy settings? can you telnet to a server on the internet on port 80?
My problem was solved. I inserted this line ip tcp adjust-mss 1452 under interface vlan 1
interface Vlan1
ip nat inside
many thanks.
glad it's now working for you. please rate useful posts and mark as resolved. thanks!
