LMS4.1->4.2: upgrade without backup during installation
Jul 2nd, 2012
Is it possible to upgrade from 4.1 to 4.2 without backup data during installation ?
Many thanks,
Elisabeth
Martin Ermel Mon, 07/02/2012 - 08:12
  • Blue, 1500 points or more
in LMS 3.x it was possible to start the installation with the "nobackup" option like:
     setup.exe nobackup
I do not know if this option still exists with the LMS 4.x train but you could give it a try
Marvin Rhoads Mon, 07/02/2012 - 13:00
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Assuming you're upgrading on the same host or appliance, you can do a direct upgrade to LMS 4.2 from version 4.1 (or 4.0.1). No backup is necessary - your configuration and any data will migrate directly. (Reference)
Of course you can always do a fresh install and rebuild from scratch too.
Martin Ermel Mon, 07/02/2012 - 16:46
Marvin, you are correct, a direct upgrade does not need a backup to get back all your data, but I think the installation process does a backup automatically - at least this was the case last week, when I performed an upgrade on a windows machine (from LMS 4.1 > LMS 4.2) and I assume that's what Elisabeth wants to avoid.
In any case, disable any anti-virus software during the upgrade procedure. This will speed up the installation and also prevents any failures caused by AV software.
paul.parquet Thu, 07/05/2012 - 07:44
The option -nobackup exists and works fine. Be carrefull to desactivate your AV software because the installation can stuck at "check lock files".
Andrewlay Sat, 07/07/2012 - 06:50
Without any backup?
Would it be better to remove the old LMS, clean up ( free tool available).
Then run the LMS4.2 from fresh.
