NAT w/ multiple VLANs and Peer VPN
Jul 2nd, 2012
My problem is that I can not ping an external address from vlan2.
I included my running config below. Here is an overview of my setup:
- There are two internal vlans,10.10.0.0 and 10.20.0.0.
- NAT on vlan 1 (10.10.0.0) works fine. I can ping an external IP address from 10.10.0.1.
- NAT on vlan 2 (10.20.0.0) does not work. I can not ping an external IP address from 10.20.0.1
- I have a peer to peer VPN Tunnel where vlan 2 has access to a peer network
I suspect that the VPN may be interfering with NAT traffice, however I believe I have the ACLs configured correctly.
Thanks in advance,
-Jesse
Building configuration...
Current configuration : 5977 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco1811
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
no logging buffered
logging console critical
enable secret 5 ###########################
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
resource policy
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name company.com
ip name-server xxx.xxx.xxx.xxx
ip name-server 8.8.8.8
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-406172510
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-406172510
revocation-check none
rsakeypair TP-self-signed-406172510
crypto pki certificate chain TP-self-signed-406172510
certificate self-signed 01
  xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  quit
username admin privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
crypto isakmp policy 2
encr aes 256
hash md5
authentication pre-share
group 5
crypto isakmp key xxxxxxxxxxxxxx address 55.5.5.5
crypto ipsec transform-set Peer_VPN_Tunnel esp-aes 256 esp-md5-hmac
crypto map crypto_map_peer_tunnel 1 ipsec-isakmp
description Tunnel to 55.5.5.5
set peer 55.5.5.5
set transform-set Peer_VPN_Tunnel
match address 100
interface FastEthernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
shutdown
duplex auto
speed auto
interface FastEthernet1
ip address 66.6.6.6 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip route-cache
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
switchport access vlan 2
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
ip address 10.10.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip route-cache
ip tcp adjust-mss 1452
interface Vlan2
ip address 10.20.0.1 255.255.255.0
no ip redirects
no ip unreachables
ip nat inside
no ip route-cache
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip route 0.0.0.0 0.0.0.0 66.6.6.1
ip http server
ip http access-class 99
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map map_dsl_nat interface FastEthernet1 overload
no logging trap
access-list 99 remark Limit Router Config Access (SSH, SDM, TELNET, etc)
access-list 99 permit 10.10.0.0 0.0.0.255 log
access-list 100 remark Encrypt tunnel traffic to peer network, only for vlan2
access-list 100 permit ip 10.20.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 remark DSL NAT
access-list 101 deny   ip 10.20.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 permit ip 10.10.0.0 0.0.0.255 any
access-list 101 permit ip 10.20.0.0 0.0.0.255 any
no cdp run
route-map map_dsl_nat permit 1
match ip address 101
control-plane
banner login ^CCCCCCCCCCCCCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
transport output telnet
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class 99 in
transport input ssh
line vty 5 15
access-class 99 in
transport input ssh
scheduler allocate 4000 1000
scheduler interval 500
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Overall Rating: 5 (1 ratings)
Harish Balakrishnan Sun, 09/30/2012 - 04:34
  • Silver, 250 points or more
Hello Jessem,
remove the following line and see how does it go
regards
Harish.
Jon Marshall Sun, 09/30/2012 - 06:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jesse
I can't see anything obviously wrong with your config. So some quick checks.
1) does the VPN work
2) from a client in vlan 2 can you ping the vlan 1 interface
3) from a client in vlan 2 can you ping the fa1 interface IP
4) What does a traceroute from a client in vlan 2 show
5) when you try to ping an external IP from a client in vlan 2 can you see any activity on the IPSEC tunnel
Note it is best to do all these tests from a client and not from the router itself ie. don't use the vlan 2 IP as the source IP.
Jon
Jeff Van Houten Sun, 09/30/2012 - 06:55
If these are real addresses, your default route next hop and your Internet facing interface are not in the same subnet.
Jon Marshall Sun, 09/30/2012 - 07:05
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jeff
Good spot although it begs the question why a device in vlan 1 can access internet addresses ?
Jon
Jeff Van Houten Sun, 09/30/2012 - 09:10
I didn't imply it would. But if there is an error in routing its my experience to fix that first.
