ASA asdm not working
nareh84
Level 3
Level 3
hi,
when i am trying to access the webpage for asdm then the internet explorer is showing "internet explorer can not display the webpage" from the inside interface. following is the show version and show runing config. i checked with asdm 6.2.1 and 6.4.9.kindly suggest what could be the reason..
CBAH# sh version
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.4(9)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
CBAH up 15 hours 1 min
Hardware:   ASA5520, 2048 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: GigabitEthernet0/0  : address is c84c.7599.4810, irq 9
1: Ext: GigabitEthernet0/1  : address is c84c.7599.4811, irq 9
2: Ext: GigabitEthernet0/2  : address is c84c.7599.4812, irq 9
3: Ext: GigabitEthernet0/3  : address is c84c.7599.4813, irq 9
4: Ext: Management0/0       : address is c84c.7599.480f, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 150
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Disabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
SSL VPN Peers                : 2
Total VPN Peers              : 750
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
Botnet Traffic Filter        : Disabled
This platform has an ASA 5520 VPN Plus license.
Serial Number: JMX1432L0JM
Running Activation Key: 0x042cd360 0x4c819429 0xf4927584 0x8ea0082c 0x8f3d07bf
Configuration register is 0x1
Configuration last modified by enable_15 at 03:19:58.868 UTC Tue Jul 3 2012
show run
ASA Version 8.2(1)
hostname CBAH
domain-name corinthia.local
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
nameif inside
security-level 100
ip address 192.168.1.216 255.255.255.0
interface GigabitEthernet0/1
nameif testing
security-level 100
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
<--- More --->
interface GigabitEthernet0/3
nameif outside
security-level 0
ip address 62.240.63.45 255.255.255.248
interface Management0/0
shutdown
nameif management
security-level 100
no ip address
management-only
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 62.240.32.5
name-server 62.68.42.2
name-server 4.2.2.2
name-server 4.2.2.3
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit ip any any
access-list INTERNET extended permit ip 192.168.1.0 255.255.255.0 any
<--- More --->
access-list INTERNET extended permit ip 192.168.2.0 255.255.255.0 any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu management 1500
mtu testing 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 access-list INTERNET
nat (inside) 1 192.168.1.0 255.255.255.0
nat (testing) 1 192.168.2.0 255.255.255.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 62.240.63.42 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
<--- More --->
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
<--- More --->
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:e8c7560ce2dc8a100cc77f09a2b80393
: end
CBAH# sh flash:
--#--  --length--  -----date/time------  path
  124  16275456    Aug 03 2010 10:09:54  asa821-k8.bin
  125  11348300    Aug 03 2010 12:17:30  asdm-621.bin
    3  4096        Jan 01 2003 00:03:50  log
   10  4096        Jan 01 2003 00:03:58  crypto_archive
   11  4096        Jan 01 2003 00:04:30  coredumpinfo
   12  43          Jul 03 2012 03:18:45  coredumpinfo/coredump.cfg
  127  12105313    Aug 03 2010 12:14:58  csd_3.5.841-k9.pkg
  128  4096        Aug 03 2010 12:15:02  sdesktop
  135  1462        Aug 03 2010 12:15:02  sdesktop/data.xml
  129  2857568     Aug 03 2010 12:15:02  anyconnect-wince-ARMv4I-2.4.1012-k9.pkg
  130  3203909     Aug 03 2010 12:15:04  anyconnect-win-2.4.1012-k9.pkg
  131  4832344     Aug 03 2010 12:15:06  anyconnect-macosx-i386-2.4.1012-k9.pkg
  132  5209423     Aug 03 2010 12:15:08  anyconnect-linux-2.4.1012-k9.pkg
  133  18927088    Jun 28 2012 08:09:30  asdm-649.bin
The luink shoudl be working, I tried that again:
https://tools.cisco.com/SWIFT/LicensingUI/loadDemoLicensee?FormId=139
To enter the license you need to do;
activation-key <5 tuple license key>
If the link does not work, send an e-mail to licensing@cisco.com and they would send you the license file.
Varun Rao
Security Team,
Cisco TAC
Varun Rao
8 Replies 8
varrao
Level 10
Level 10
You would need a 3DES license for it, kindly download and install the limcense from the link below, and it should work after that:
Its for free.
Hope that helps.
Varun Rao
Security Team,
Cisco TAC
Varun Rao
hi ,
the link is not working . Also tell me the proceedure to enter that license information in cisco asa.
Marvin Rhoads
Is the system you are coming from on the 192.168.1.0/24 network? The configuration command "http 192.168.1.0 255.255.255.0 inside" restricts ASDM access to systems there.
Your ASDM image is on the disk0:/ filesystem, yes? Please check "dir disk0: to confirm. ("show flash" is ambiguous in that respect.)
hi Marvin,
I checked disk0: .. yes the files are there.
Varun Rao
Security Team,
Cisco TAC
Varun Rao
if user iscoming from 192.168.1.0 and ASDM is located on disk0:/ then I suspect client configuration issues.
Can you check output of asdm log ("show log asdm" from cli) during unsuccessful login attempt? Have you tried using ASDM applet on a working machine? Capture traffic on Wireshark while trying to login. These are all steps I would take in troubleshooting.
hi,
I activated the license but still it was not working..it worked when i added the command "ssl encryption rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1" and is working now..thanx
Interesting..i tore my hair off all day trying to get asdm to work after loading image again..i erased disk mistakenly..
at the end of the day, the command above also worked for me..gem
