Upgrade File from CUCM 6.1 to CUCM 8.5
Jul 3rd, 2012
I am doing an upgrade. I'd like you to confirm me if the following files for installation are correct:
Active partition: 6.1.2.1000-13
File to Install: UCSInstall_UCOS_6.1.5.10000-10.sgn
Inactive Partition: 6.1.2.1000-13
Active Partition: 6.1.5.10000-10
File to install: UCSInstall_UCOS_8.5.1.10000-26.sgn
Inactive Partition: 6.1.5.10000-10
Active Partition: 8.5.1.1000-26
Are those all file to complete the upgrade from 6.1.2 to 8.5.1?
The file: ciscocm.allow_upgrades_to_unrestricted.cop.sgn, is necesary?
Thanks!
Overall Rating: 3 (1 ratings)
Chris Deren Tue, 07/03/2012 - 07:21
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Is there a reason you want to go to base 8.5.1 vs. 8.5.1SU4 for example? It would take the same amount of effort.
Check out compatibility matrix for supported upgrade paths:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
Why would you want to go to unrestricted version? What country are you in?  Most typically installations are Restricted unless you cannot use it because you are in a contry that Cisco does not allow it.
HTH,
Chris
matthewlogan46 Tue, 07/03/2012 - 14:40
Thanks Chris.
About the version there is no particular reason. My country is Chile.
Chris Deren Tue, 07/03/2012 - 14:44
  • Hall of Fame,
You should not need unrestricted version in Chile, so no need to run the cop file.
Chris
Chris Deren Wed, 07/04/2012 - 06:53
  • Hall of Fame,
Matthew,
Did you require further assistance hence the low rating?
Chris
