Port-Channel Issue: SP-5-CANNOT_BUNDLE_LACP
Answered Question
Jul 3rd, 2012
I'm having an issue with the port-channel coming up. Right now it's "down down". I'm not really sure why. All other port-channels on the 6500's in VSS work fine. This one seems to be giving me an issue though.
-Both interfaces that are using this port-channel are "up up".
-I've done "shut's, no shut's" on all interfaces involved.
sh etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      N - not in use, no aggregation
        f - failed to allocate aggregator
        M - not in use, no aggregation due to minimum links not met
        m - not in use, port not aggregated due to minimum links not met
        u - unsuitable for bundling
        d - default port
Po4(SD)         LACP      Gi1/1/4(I)     Gi2/1/4(I)
interface Port-channel4
switchport
switchport access vlan (vlan number)
switchport mode access
load-interval 30
flowcontrol receive desired
spanning-tree portfast edge
end
interface GigabitEthernet1/1/4
switchport
load-interval 30
channel-protocol lacp
channel-group 4 mode active
end
interface GigabitEthernet2/1/4
switchport
load-interval 30
end
sh log
149886: Jul  3 15:20:34 CDT: %EC-SW1_SP-5-CANNOT_BUNDLE_LACP: Gi2/1/4 is not compatible with aggregators in channel 4 and cannot attach to them (flow control receive of Gi2/1/4 is desired, Gi1/1/4 is on)
149887: Jul  3 15:20:35 CDT: %EC-SW2_SPSTBY-5-CANNOT_BUNDLE_LACP: Gi2/1/4 is not compatible with aggregators in channel 4 and cannot attach to them (flow control receive of Gi2/1/4 is desired, Gi1/1/4 is on)
Thank you for your help.
Correct Answer by pstebner10 about 5 years 3 weeks ago
Hi Mark-
What is on the other end of the port-channel? It looks like Gi1/1/4 is negotiating flow control with the far end and going into a receive 'on' state, while Gi2/1/4 is not. They both need to be in the same state to form a bundle. You can check the status with sh int Gi1/1/4 flowcontrol for example.
I would either look to change the other side's config or set flowcontrol receive off on both local switchports.
HTH,
Paul
Overall Rating: 5 (1 ratings)
Correct Answer
pstebner10 Tue, 07/03/2012 - 19:35
Hi Mark-
HTH,
Paul
Mark Pedersen Wed, 07/04/2012 - 06:47
show inter gig 1/1/4 flowcontrol
Port          Send FlowControl  Receive FlowControl  RxPause TxPause
                admin    oper         admin    oper
Gi1/1/4      desired  on            on         on                0       0
show inter gig 2/1/4 flowcontrol
Gi2/1/4      desired  on              on         on                 0          0
I turned off flowcontrol receive like you suggested but still no luck. Then I disjoined the two interfaces from the port-channel, deleted the port-channel, recreated it, and then rejoined the interfaces to the port-channel while having flowcontrol receive off. Still no luck. I am assuming the other end, which is not a cisco device, doesn't support port-channeling in its current state. I will get with the people who administer it and see what I can work out.
Thank you all for your help.
rpatnaik_slf Thu, 12/11/2014 - 08:47
Did you ever get an answer?  I have a case with Cisco opened and they also recommended disabling the flow control.  But it still seems that you still have an issue.  Your output above though is misleading as it seems that gig2/14 has flow enabled "oper - on" even though "admin is desired.
My situation is the non-VSS 6509's have flow-control receive desired and the 6880 VSS end does not.  One L3 is up with the 6509 (same config) no issues.  The other has one GE link down with the PO.
Cheers,
Rash
Mark Pedersen Thu, 03/14/2013 - 07:53
It turns out the non-cisco devices on the other end weren't capable of handling port-channeling.
Vivek Ganapathi Tue, 07/03/2012 - 19:37
  • Silver, 250 points or more
Hello Mark,
What is the IOS image you are running ?
dmamadjanov Tue, 07/03/2012 - 20:18
Trying changing the mode to Desirable
Sandeep Choudhary Wed, 07/04/2012 - 07:18
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
HI Mark,
1. Can you please check your ethernet card ...where this port channel connected..on the server.
    may be there are 2 different card.
2. from cisco websites:
Error Message
Explanation
This port has different port attributes than other ports within the port channel.
Recommended Action
Match the port attributes to that of the port channel.
Please rate if it helps.
EC-5-CANNOT_BUNDLE_LACP: [char] is not compatible with aggregators in
channel [dec] and cannot attach to them ([char])
Related Content
