Cisco 887 slow loading web page
Answered Question
Jul 3rd, 2012
Hello all!
I've just recently upgraded a Cisco 877 to 887W router.
I basically copied most of the config across to the router with no problem.
ppp chap hostname and password all ok. ATM and Dialer1 interface comes up.
The problem I'm having is when I open Internet Explorer up, default homepage is Google. Google loads up fine, type a search is fine but when you click on the link or type URL, for example BBC News or Sky Sports, it takes a long time to load or times out (Page cannot be displayed)
DNS servers configured on Cisco router are:
8.8.8.8 and Virgin's DNS servers.
NSLOOKUP in cmd prompt it returns IP add no problem. however in web browser it fails except for Google.
However, with the same config on a 877 everything works perfectly... any ideas guys?
Cisco 877 running 12.4
Cisco 887 running 15.0
Thanks in advance
Correct Answer by cadet alain about 4 years 8 months ago
have you got ip tcp mss-adjust 1452 and ip mtu 1492 configured on dialer  interface ?
Regards.
Alain.
Overall Rating: 5 (1 ratings)
Correct Answer
cadet alain Wed, 07/04/2012 - 01:58
  • Purple, 4500 points or more
Regards.
Alain.
JDMJeffy84 Tue, 11/20/2012 - 02:39
slow reply but yeah it was MTU issue, adjusted MTU size on VLAN 1 to 1412 and dialer & ATM to 1452, bingo everything started working, cheers
Michael Grevald Tue, 11/19/2013 - 05:23
@JDMJeffy84
Got a question for you, just for myself to understand the config - why do you have:
ip dns server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 interface Dialer0
ip dns server
these commands in two places (top and bottom) or was that just a typo?
And you have the "ip route" command as different in both?
JDMJeffy84 Wed, 07/04/2012 - 03:09
Hi Alain,
yes both configs confirgured on dialer interface.
interface ATM0
ip virtual-reassembly in
ip tcp adjust-mss 1452
no atm ilmi-keepalive
hold-queue 224 in
interface ATM0.1 point-to-point
ip flow ingress
pvc 0/38
  pppoe-client dial-pool-number 1
ip dns server
interface Dialer1
ip address negotiated
ip access-group 102 in
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname [email protected]
ppp chap password 7 xxxx
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
it's wierd only www.google.com works fine and making a search but click on the link it fails or takes an age to load.
if I type show host on the router I can see the hostname resolving
johnlloyd_13 Wed, 07/04/2012 - 03:22
  • Blue, 1500 points or more
hi,
could you temporarily remove these lines and see if performance gets any better?
no ip nbar protocol-discovery
no ip inspect CO_Firewall in
no ip inspect CO_Firewall out
JDMJeffy84 Wed, 07/04/2012 - 03:47
1. removed :
Google does not load
2.
Google takes a long time to load but other webpages still take a long time or times out
3.
Google loads up instantly but other webpages still take a long time or times out
johnlloyd_13 Wed, 07/04/2012 - 03:53
thanks for the update! could you post your running-config and remove any sensitive info?
cadet alain Wed, 07/04/2012 - 03:55
could you post the entire running-config.
Regards.
Alain.
johnlloyd_13 Thu, 07/05/2012 - 07:19
Remove this line under your ATM interface and try again. Are you doing web surfing from a wired or wireless LAN connection?
int atm0
no hold-queue 224 in
JDMJeffy84 Thu, 07/05/2012 - 08:34
same John, I am using wired connection.
I have looked into the ip inspect part. I can get a established connection for google.
But only Half open session for any other webpages. I can see the IP Address so DNS is working? nslookup brings up the correct web name.
So I'm guessing IP inspect is the problem?
I've removed all the inspect only leaving UDP and TCP - still the same.
If I remove TCP everything fails
AHH headache
johnlloyd_13 Fri, 07/06/2012 - 02:31
Retain the ip inspect command in VLAN 1 interface and remove these lines:
int d1
int atm0
phoenix3195 Fri, 07/06/2012 - 06:56
Try to lower MTU and adjust TCP mss to a value lower than 1450
conf t
int di 1
ip mtu 1480
ip tcp adjust-mss 1420 (or you migh need to have it lower than that, i usually adjust it to 1380)
rizwanr74 Fri, 07/06/2012 - 07:28
  • Gold, 750 points or more
Hi Jeffy,
Please remove the highlighted lines below.
interface ATM0
Please copy the highlighted line on the interface wlan-ap0.
interface wlan-ap0
Please update me.
thanks
JDMJeffy84 Sun, 07/08/2012 - 01:46
Guys, I think I resolved this the model we're using doesn't support ADSL only supports ADSL2/ 2+ (
CISCO887W-GN-E-K9)
Can someone confirm this? Cisco release notes doesn't state this.
if it doesn't support ADSL then why does the ATM/ Dialer interface come up and establishes ppp connection with provider.
And why does Google homepage and search function works?
ericsonmisagal Sun, 07/08/2012 - 05:42
Try with clean configuration and see...
interface ATM0
no ip address
pvc vpi/vci
interface Vlan1
ip address aaa.bbb.ccc.ddd yyy.yyy.yyy.yyy
ip nat inside
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname xxxx
ppp chap password yyyy
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit any
Good Luck.
Paolo Bevilacqua Fri, 09/07/2012 - 22:31
  • Hall of Fame,
    Founding Member
CISCO887W-GN-E-K9)
Actually it supports all types of ADSL.
eoghan_murtagh Fri, 09/07/2012 - 06:37
Hi All,
Thanks for this post the ip tcp adjust-mss 1452 (on the dialer interface) setting solved this problem for me on 2 new Cisco 887 routers.
Thanks for your help,
Eoghan
