Warning message
Cisco Jabber Video Telepresence Integration
Answered Question
Jul 3rd, 2012
How are you?
I have a question, can Cisco Jabber Video register to a VCS standalone? or is it necesary also a TMS? on its data sheet it says that a requirement is the TMS but if a customer has a VCS with TP EP registered to it, it wants to enable jabber video as well on the network and wants to know if it can be done without the need to get a TMS.
can anyone help me?
please
sincerely,
Dante Verastegui
Correct Answer by Tomonori Taniguchi about 5 years 1 month ago
For simple Jabber Video deployment can be done by using VCS Expressway Starter Pack as Martin has mention already.
VCS Expressway Starter Pack has inbuilt provisioning account management feature so TMS won’t be required.
VCS Expressway Starter Pack (from version X7.1) supports MX200 as principal/provisioning devices.
You may also able to register MX200 on VCS Expressway Starter Pack as H.323 Endpoint (with H.350 enabling authentication).
For CTS series Endpoint registration, currently need include CUCM on deployment and have SIP trunk between CUCM and VCS.
Correct Answer by Martin Koch about 5 years 1 month ago
For a proof of concept a VCS starter pack maybe doable, but if you start with
CTS systems I would say its a nogo
You would use CUCM for the CTS systems, have the VCS-C for your internal network where
JabberVideo and MX200 can register and then the VCS-E for external/b2b communication and
maybe external registrations + TMS to manage.
As the requirement grow from each message I really suggest you reach out to Cisco (Partner). :-)
Please rate the messages using the stars below!
Overall Rating: 0 (2 ratings)
Martin Koch Tue, 07/03/2012 - 15:05
  • Red, 2250 points or more
For smaller deployments from scratch with no advanced internal network you could look into the
VCS Starter Pack Express:
http://www.cisco.com/en/US/prod/collateral/ps7060/ps11305/ps11315/ps11337/data_sheet_c78-697075.html
This can scale up to 25 traversal calls and 50 registrations.
But if you already have a vcs in place (like it sounds here) or there is the though of management or
its just a bit more complex or specific features are required you have to use TMS&VCS.
http://www.cisco.com/en/US/prod/collateral/ps7060/ps11303/ps11310/ps11328/data_sheet_c78-628609.html
where you can also read:
Cisco Network infrastructure requirements
• Cisco TelePresence Management Suite Version 12.6 or later
• Cisco TelePresence Video Communication Server Version X5.2 or later
For the standard deployment (tms/vcs)
In technical terms the client only registers to the vcs and also the provisioning of the setting to the client
will be done via the vcs, but the management of the accounts and the replication of these settings down to
the vcs is done by TMS, both are working hand in hand and both need to be in place.
There might be 3rd partys who can offer you Jabber Video registrations as well.
I would talk to your cisco partner or if you are a partner to cisco, they will be able to help you.
Martin
Dante Verastegu... Tue, 07/03/2012 - 15:11
Hi Martin,
Thanks for getting back to me.
Can the VCS Starter register Inmersive and multipurpose EP such as CTS 1300 or MX200?
They want to be able to use both of those end points to communicate with Jabber Video using the PrecissionHD USB camara.
I'll be looking forward to your reply
sincerely,
Dante V.
Correct Answer
Martin Koch Tue, 07/03/2012 - 16:22
Correct Answer
Tomonori Taniguchi Tue, 07/03/2012 - 18:06
  • Cisco Employee,
Vinod Kembhavi Tue, 04/02/2013 - 20:30
Hi ,
I have a same query..
can i register Jabber client movi directly on VCS expressway without TMS provisioning.
I don't see VCS express starter pack, I have below option key,
still TMS is not installed so I want to make POC setup without TMS.
Tomonori Taniguchi Tue, 04/02/2013 - 20:55
  • Cisco Employee,
No, for VCS Expressway you will need TMS to provisioning user account and client configuration (provisioning template).
VCS Starter Pack Expressway which include provisioning feature and doesn’t require TMS to provisioning the client configuration and user account.
