Warning message
second ssid in controller
Answered Question
Jul 3rd, 2012
We have one ssid currently in our wireless controller. Second one needs to be added.
the setup has an ap group created also. How do i make sure that the second ssid gets broadcasted & is functional after it is created.
It will have an internal dhcp server on the controller itself.
Also will all the ap's in the network propogate this new ssid. Thanks in advance
Correct Answer by Amjad Abdullah about 5 years 1 month ago
Your new SSID will be part of the default-group when it is created. If you have APs under that group then the SSID will appear on those groups.
If you don't have any AP under this group (default-group) then you need to add the new SSID to be broadcasted on the groups that you want.
From WLAN->Advanced-> AP Groups you choose the groups and configure them to broadcast the new SSID.
Amjad
Overall Rating: 5 (1 ratings)
Correct Answer
Amjad Abdullah Tue, 07/03/2012 - 22:41
  • Red, 2250 points or more
Amjad
