Help with Port Security
Jul 4th, 2012
Dear All,
please help with the proper configuration that i should use to configure port security on cisco 2960 switch with the below setup
i saw two types of setup and i don`t know which one is correct or even better
1-
interface GigabitEthernet1/0/2
switchport access vlan 2
switchport mode access
switchport voice vlan 12
switchport port-security maximum 2
switchport port-security maximum 1 vlan access
switchport port-security maximum 1 vlan voice
switchport port-security violation restrict
switchport port-security mac-address x.x.x.x vlan voice                      >>     x.x.x.x is the ip phone mac
switchport port-security mac-address y.y.y.y                                     >>    y.y.y.y is the pc mac
spanning-tree portfast
2-
switchport port-security maximum 3
switchport port-security maximum 2 vlan access
switchport port-security mac-address x.x.x.x                                       >>     x.x.x.x is the ip phone mac
my other question beside first of which implementation is better is are these commands important to apply ?
Ali
Giuseppe Larosa Wed, 07/04/2012 - 01:38
  • Hall of Fame,
    Founding Member
Hello Ali.
the second configuration template is more correct because during IP phone boot phase it will first be in access data vlan and then later it will reboot and it will be in voice vlan.
So you need to take in account this in port security configuration providing space for two MAC addresses on the data access vlan
With the first configuration you may face issues in case the phone is rebooted with a PC connected to the PC port.
Hope to help
Giuseppe
Sandeep Choudhary Wed, 07/04/2012 - 01:47
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Ali,
Mr Larosa is absolutely right.
The IP Phone can use 2 mac adresses, so you need to set the appropriate number of maximum mac adresses. Try to set it to 3.
according to this document:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22ea/SCG/swvoip.html#wp1030836
When you enable port security on an interface that  is also configured with a voice VLAN, you must set the maximum allowed  secure addresses on the port to at least two plus the maximum number of  secure addresses allowed on the access VLAN. When the port is connected  to a Cisco IP phone, the IP phone requires up to two MAC addresses. The  address of the IP phone is learned on the voice VLAN, and it might or  might not be learned on the access VLAN. Connecting a PC to the IP phone  requires additional MAC addresses.
please rate if it helps.
Related Content
