Warning message
[AnyConnect] Use SmartCardLogon Certificate
Jul 4th, 2012
We are using AnyConnect with Certificate authentication and it works fine.
Our certificates are on USB Token.
When we are connecting to AnyConnect, middleware of the USB Token asks for PIN (to use private key)
After authentication and authorization, we are connected
Now we are using USB Token for SmartCardLogon on Windows platforms.
We have to enter our PIN to log in. It uses Windows Cryptographic Service Provider instead of token middleware.
When we are connecting to AnyConnect, middleware asked for PIN again.
We want to enter PIN only once.
Is it possible to use SmartCardLogon authentication? (by using Windows Cryptographic Service Provider)
Thanks for your help,
Patrick
