Cisco RV042 - WAN2 PPPOE connection
Jul 5th, 2012
I have an issue with Cisco RV042  i have two Internet access connection from my ISP  one with 30Mbps and the other with 8Mbps.
i have 30Mbps in WAN1 and 8Mbps on WA2
my issue that i was connecting both of the WAN connections using DHCP mode and it was working fine and the ISP modem was terminating the PPPOE
now i decided to use PPPOE on the Cisco RV042 and change the ISP modem to bridge mode.
WAN1 is working were as WAN2 is not working.
i tried to factory reset, shift links, in all cases WAN2 if its on PPPOE does not go up.
i am using latest firmware from cisco.com.
can anyone help ?
simonslater Sat, 07/07/2012 - 17:20
  • Silver, 250 points or more
Are both ISP modems the same make and have the same firmware? is the MTU set the same?
Was there an issue with using the two Modems in DHCP mode?
Regards Simon
http://www.linksysinfo.org
thabet.bakheet Mon, 07/09/2012 - 11:53
hi simon
yes. both are huwaui gpon ont provided from my isp as bridge mode.
i tested both connections on wan1 and its working
when i try to use both wan1 and wan2.  only wan 1 cones up
i tried to change load balancing mode to fail over mode. but it didnt work.
only with dhcp mode it work.
simonslater Mon, 07/09/2012 - 18:46
Fail over will put one wan port to sleep until the main wan drops connection, then the other wan port becomes the primary. Do you have different PPPoE login details setup for each wan?
