WLC serving multiple sites
Answered Question
Jul 5th, 2012
Is there a way to stop the broadcasting of certain SSID's on certain access points? The customer has a WLC deployed at their main location, with a few APs hanging off of it at a remote. It would be nice if the remote location only broadcasted the networks it can support locally. Thanks!
Correct Answer by Amjad Abdullah about 5 years 1 month ago
You need to use ap groups.
Here is a config example: www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example0...
Amjad
Correct Answer by Scott Fella about 5 years 1 month ago
You need to define and use AP Groups. This allows you to specify what APs will have what ssids.
Overall Rating: 5 (2 ratings)
Correct Answer
Scott Fella Thu, 07/05/2012 - 10:06
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
allenelson Tue, 08/07/2012 - 11:57
Thank you very much fellas, that worked perfectly.
Related Content
Trending Topics - Security & Network
