Warning message
ASA5520 Dual-Tier NAT
Jul 6th, 2012
Hey all:
I am having some issues getting internet traffic to pass to inside hosts on Two Cisco ASA 5520s running 8.4 ASA IOS.
The set up is a 2-tiered FW.
Inside Hosts -- ASA5520 -- DMZ Hosts -- ASA5520 -- Internet Provider
Inside FW Network: 10.10.10.0/24
Perimeter FW Network: 10.10.0.0/24
NAT Network: 172.16.10.0/24
Real IP Network: 192.168.1.0/24
Inside Host: 10.10.10.10
Inside FW: 10.10.10.1/24
Inside NAT: nat (inside,outside) source static 10.10.10.10 172.16.10.10 unidirectional
Interface GigabitEthernet 0/0
nameif outside
ip address 10.10.5.2 255.255.255.252
Interface GigabitEthernet 0/1
nameif inside
ip address 10.10.10.1 255.255.255.0
Outside FW: 10.10.0.1/24
Outside NAT: nat (inside,outside) source static 172.16.10.10 192.168.1.225 unidirectional
nameif outside
ip address 192.168.1.2 255.255.255.0
nameif inside
ip address 10.10.5.1 255.255.255.252
Interface GigabitEthernet 0/2
nameif dmz
ip address 10.10.0.1 255.255.255.0
Interfaces are connected through 10.10.5.0/30 network
Inside FW route:
route outside 0.0.0.0 0.0.0.0 10.10.5.1
Outside FW routes:
route outside 0.0.0.0 0.0.0.0 192.168.1.1
route inside 10.10.10.0 255.255.255.0 10.10.5.2
I can see the traffic passing, but I am just getting SYN Timeouts and a few TCP reset-I and TCP reset-O messages in the logs.
Jennifer Halim Fri, 07/06/2012 - 02:30
  • Cisco Employee,
You would need to configure route for the 172.16.10.10 NATed address on the Outside FW because you are NATing it to that ip address, it doesn't know and doesn't need to route to the real subnet (10.10.10.0/24), hence you don't need the following route:
What you need is:
route inside 172.16.10.10 255.255.255.255 10.10.5.2
Gourav Bathla Fri, 07/06/2012 - 04:55
Another option you can go for
1) On Inside Firewall
object network server
host 10.10.10.10
access-list OUTSIDEIN extended permit ip any object server
access-group OUTSIDEIN in interface outside
2) On outside firewall
host 10.10.10.10
nat (inside,outside) static 192.168.1.225
