UCCX 5.0 vs 8.5 ODBC for Crystal Reports
Answered Question
Jul 6th, 2012
  • Gold, 750 points or more
today customer has a server that runs Crystal Reports via an ODBC connection to UCCX 5.0 to get some custom reports about contact center calls. We are upgrading UCCX 5.0 to 8.5. Will this functionality be affected? Is there anything that needs to be updated on the CR's side post upgrade?
Correct Answer by Anthony Holloway about 5 years 1 month ago
The short answer is yes.  UCCX 5x uses MSSQL, and UCCX 8.5 uses IBM Informix.  Therefore, you will need to install the Informix ODBC driver on your CR server/workstation, and recreate your DSN to UCCX using the new driver.  That's at the bare minimum.
I would reference the HRC Admin and Dev guide to get the full details on how to accomplish this in 8.5.
Happy reporting!
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Overall Rating: 5 (1 ratings)
Correct Answer
Anthony Holloway Fri, 07/06/2012 - 07:53
  • Purple, 4500 points or more
Happy reporting!
Anthony Holloway
Aaron Harrison Fri, 07/06/2012 - 10:38
  • Community Spotlight Award,
    Member's Choice, May 2015
Just a few words in addition to Anthony's comments (+5)
I don't know how you do your reporting exactly, but typically the work I do involves creating a stored procedure that generates a results table from various other tables, and then presenting that in Crystal via HRC.
Basically the database schema, and the Crystal templates, has not changed with the transition to Informix.
However - the syntax and style of writing a procedure for Informix is very different to the cuddly MMSL world. If you use those, prepare for some learning. If you just query simple tables, then you might have an easy ride.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Related Content
