Warning message
Speed test tool to test switch upgrade?
Jul 6th, 2012
I've added a few gigabitethernet SFP modules to switches to upgrade the trunk ports from 100mb to 1gb and wondered if there is any stress testing tools where I can get the ports to use over 100mb and also monitor that it did use more that 100mb?
At the moment I am copying large files across the switches between VLANs and it seems no quicker and I need to grab some stats.
Thanks in advance for your help.
Leo Laohoo Fri, 07/06/2012 - 23:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
This is going to be a very hot topic.
How sure are you that your source client and/or your destination client can handle 1 Gbps of traffic?
Karsten Iwen Fri, 07/06/2012 - 23:58
  • Purple, 4500 points or more
    2017 Firewalling, VPN
For testing the speed Iperf is a quite common tool. If you want to monitor your bandwidth-usage over longer time you should poll the interface stats with SNMP. Free tools for that are MRTG, Zenoss, Cacti, Nagios, ...
Andy White Sat, 07/07/2012 - 12:12
Is iperf linux or windows based, I will look into that?
Is Speedtest Mini basically a way of testing bandwidth internally instead of testing your internet speed?  If so that is brilliant!
Andy White Sat, 07/07/2012 - 12:41
Got speedtest mini working, my PC has a 1 gig nic and is on 3750G trunked to another 3750G where the speedtest mini server is and I only get 250mb download and upload, is this normal?
mikegrous Sat, 07/07/2012 - 13:37
You have to remember that with this speedtest you will also have the NIC of the PC and server in the equasion. With our speedtest server i have hit the 1 gig 1 gig speeds. The 250 meg could also be some network limitation? or link utilization etc etc. iperf is a command line tool only. Unless you download jperf. It is a java version. You can try that from server to PC too.
Andy White Sun, 07/08/2012 - 03:48
What do you make if the different results:
I ran speedtest mini and each way is nearly 100mb (100mb network) but iperf returns completely different results:
C:\>iperf.exe -c 192.168.90.11
Client connecting to 192.168.90.11, TCP port 5001
TCP window size: 8.00 KByte (default)
[1884] local 192.168.38.10 port 2998 connected with 192.168.90.11 port 5001
[ ID] Interval       Transfer     Bandwidth
[1884]  0.0-10.0 sec  20.0 MBytes  16.8 Mbits/sec
C:\>
I have run the tests many times and both return the same kind of results.
erpylko Sun, 07/08/2012 - 04:41
  • Cisco Employee,
I don't know, I haven't used them. What do their terms of use say? I would expect they are free since they come from I2.
